Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 02-20-2006, 07:21 PM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default EFI return line routing
Anyone running EFI out there? If so, how did you run your return line? I was thinking along the passenger side fram rail, but have run into a quandry when I get to the e-brake bracket at the rear. My battery cable already goes through it (with a grommet). I thought about traveling along the X crossmember, but feel that will put the line awefully close to the drive shaft if there is ever trouble. I could dip under the X, but that puts the line below the frame which I think is a no-no. Not a whole lot of room on the drivers rail either.
Tom
Display Modes
