Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 06-10-2006, 11:37 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default B&B Aluminum Trunk Kit
Who has installed it? Did you use anything to bond it to the fiberglass? Is there a pannel that goes on the back of the top shelf? I think I am missing that. Any tips for lining up the DSUES fastners for drilling on the side panels?
Tom
Old 06-10-2006, 06:19 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
I think your in uncharted teritory,wish i could help .there is so little room in there as it is. why didn't they lower the gas tank 2" and move the battery to the passenger side?
the older i get the faster i was.
Old 06-10-2006, 07:09 PM
Well, I test fit the peices this afternoon. There is definately a peice missing, and I am not sure if I will end up modifying them. I have a battery cutoff mounted to the bulkhead, and this setup will limit access to that should it need work. I would need to drill out the rivets for that back panel. Also, same goes for the bolts for the seat belts, and considering they need to be swapped. I may order the panel that I am missing with a removable plate, or just modify what I have.
Tom
Old 06-11-2006, 06:49 AM
RobV's Avatar
Cobra Make, Engine: B&B, 351 W, TREMEC 600
Tom,
Just curious, why did you decide to go with aluminum in the trunk?
Old 06-11-2006, 11:01 AM
Mainly looks, plus it gives a little extra space on the shelf area. This space was going to be used to mount my cold fire suppression bottle. My other concern is that I wanted to do some track events, and am thinking the aluminum is a better idea than the capet I have now.
Old 06-16-2006, 09:36 AM
pmfranke's Avatar
shure would like to see some pictures !!!!
