Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 06-16-2006, 10:55 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Default windshield install ?
when putting the windscreen on there are alluminium escution plates that interfear with the windscreens rubber gasket. do we trim the gasket and does it (the rubber)shrink or cut the plate or let it ride on top . Does anybody have a pic of the solution?
the older i get the faster i was.
Old 06-16-2006, 12:35 PM
Cobra Make, Engine: B&B --Well built 302
I just put a little black rtv silicone there for a seal.Between the seal, gasket and post escution!!
Old 06-17-2006, 08:42 PM
RobV's Avatar
Cobra Make, Engine: B&B, 351 W, TREMEC 600
I too used black silicone under the rubber seal. In my case, I felt the rubber didn’t fit quite several places across the length of the rubber seal. I put a small bead of black silicone under the front edge of the rubber. I then taped the whole thing down to dry. I put a piece of tape on the body in front of the seal to keep things clean. The tape allowed me to clean any excess silicone away easily. I used a piece of plastic to smooth the silicone under seal where it showed on the inside.
Rob
