Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 07-14-2006, 12:26 PM
Default Rear Wheels
OK, I have a 8.8 Fox width . How wide and what backspace can I run? I have talked to several wheel suppliers and get differant answers. Iam ready to order my wheels and iam thoroughly confused. These things are to expensive to get this wrong.
Old 07-14-2006, 12:57 PM
jams's Avatar
Cobra Make, Engine: B & B
There are lots of post on this subject. I would suggest doing a search using the keyword backspacing. With the advanced search feature you can limit it to the B & B Forum.
My rear tires are 275 - 60 - 15 with an 8.8 rear. Don't remember the backspacing off hand.
Old 07-14-2006, 01:09 PM
Clois Harlan's Avatar
Do you have a narrowed rearend? If so you can run up to 10" wide rims with a 5 1/2" back space and run the 295-50 X 15" tires and still have your tires tuck under your fenders on the rear. My front backspace is 3 1/2" and I am running the tubular front A-Arms.
Clois
"Let's roll"
"Be part of Something Good
Old 07-14-2006, 01:51 PM
The rearend is not narrowed, standard Mustang converted to 5 lug and disk. I talked to the guys at North Race Cars, about a set of Team III"s and he didn't think the backspace given in the manual was correct for my set up.
Old 07-14-2006, 02:28 PM
I ran a set of 6 1/2" backspace wheels with my 8.8 like yours and they fit under the fender (almost). Your Mustang Fox Body rearend is between 58 and 61" wide and what B&B PROVIDES NOW is a 52" wide axel.
Here is a link for a narrowed 9" housing, axels, bearings, and retainers:
http://cgi.ebay.com/ebaymotors/9-For...QQcmdZViewItem
This would bolt into the same place as your 8.8 but you would need to get some brakes and a third member.
Clois
"Let's roll"
Old 07-15-2006, 12:05 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
clois have you bought from these guys ? was thinking of getting a 3.5 ratio pumpkin and switching it out . My 3.0 rear is too tall. I need some place that i can trust that doesnt want 500 bucks.
the older i get the faster i was.
Old 07-16-2006, 03:18 PM
RobV's Avatar
Cobra Make, Engine: B&B, 351 W, TREMEC 600
pmfranke, I am interested in doing the same thing. I have 3.0 on a 9" and want to go to 3.5. I have been shopping around for third member as I really don't want to rebuild mine.
Jeroka, my 2 cent's worth is that you're probably right about the manual being incorrect for your set up. I would not go with the manual numbers, but a call to Barry or Brian might do you some good. If you didn't get the optional tubular front end you might be limited on your back space options.
Rob
