Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 10-16-2006, 04:50 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Default ride height adjusted by coil overs?
i've got the coilovers adjusted all the way to the top of the threaded part in the front . is that the way everybody has the front's set? there sure is'nt much travel. does the spring just sit in the upper cup or did b and b forget to give me a rubber spacer like most cars i have worked on?
the older i get the faster i was.
Old 10-21-2006, 05:10 AM
jams's Avatar
Cobra Make, Engine: B & B
I'm adjusted 1/2 - 3/4 so I still have some room to play around with. Sounds like you need either some longer springs or springs that can handle more weight.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Display Modes
