10-28-2006, 02:35 PM
OR
Cobra Make, Engine: B&B 302 GT40, T5 5sp, 9"rear end
side pipes
What are you guys using for a gasket from the header.
10-29-2006, 06:24 AM
NJ
Cobra Make, Engine: B & B
High temp Sealer RTV in a tube (or something like that) Works great! No problems 4 years later.
10-29-2006, 06:55 AM
WI
Cobra Make, Engine: B+B 351w #112
I didn't use anything! I'm sure it leaks. I think it is sucking in air because I can get up to 4 foot flames out the exhaust on downshifts! Pull up to a ricer at night and get their attention! Jim
10-29-2006, 09:47 AM
Cobra Make, Engine: SPF 2046; P.E. Aluminum 427 Windsor.
Finish Line sells sidepipe gaskets for $24. a pair.
10-30-2006, 05:09 AM
Bought high temp gasket material in a sheet at Napa and used the pipe to make a template. Then just cut it out with a hole saw and sissors.
10-30-2006, 02:38 PM
Cobra Make, Engine: B&B 351/402 Fi roller everything
I cut one out of a piece of copper (roofing) sheet metal.works good so far.
the older i get the faster i was.
04-23-2007, 06:32 PM
Senior ClubCobra Member
Permatex - same like Jams
04-23-2007, 08:45 PM
AL
side pipe gasket
Red high temp RTV.
I bought a 2' x 2' sheet of .002" laminated aluminum .048" thick for $50 from McMaster-Carr. I made two gaskets and installed them using the red RTV. I'll let you know in a couple of weeks if it's better than just RTV. I've tried 2 or 3 gaskets over the years but the red RTV worked the best. I think the soft laminated aluminum will work.
See ya'll in Ohio in June!
Dwight
04-27-2007, 01:45 PM
I made some from gasket material that NAPA sells, then I had to remove the sidepipes to get them ceramic coated and didn't use anything when I put them back together. I can't tell the difference myself!
04-27-2007, 03:22 PM
SC
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Earl's Aluminum Gasket Frames with inserts......4 years and NO PROBLEMO!!
About $40.00 from Summit and re-usable with new inserts!!
Coosawjack
04-27-2007, 04:52 PM
no gasket just high temp rtv silicone , no leaks , no loose or broken header bolts . bin 2 years and no problems.
04-28-2007, 04:09 AM
IL
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Permatex copper here. Had a slight leak last year, but I think that was due to some of the bolts backing off. Have to keep an eye on those.
04-28-2007, 05:14 PM
il
Cobra Make, Engine: B&B 302ci
3 Years with red hi-temp rtv no leaks cost $6.00
04-28-2007, 06:34 PM
MD
Cobra Make, Engine: Unique, 427SO, it runs
4 years with Red Permatex RTV........no leaks.
Clay
