Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-05-2007, 03:16 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
Default Need to Mount Alternator at 12 O'Clock
My built up 351W engine came with the alternator hanging off the head at about 7 or 8 O'Clock. High and Narrow frame rails of my B & B are in the way so I need to mount it vertically. My set up is V belt. I ordered a Summit SME-2003 and it doesn't fit. The Triangular bracket is just a little too wide and the spacers are all too long. Almosts seems like a measurement or machining issue on the triangle bracket. I can shorted the spacers and maybe even Mill out the bracket holes but really don't want to. Turns out there are about 5 water pumps Ford has used and I don't know which one I have except it doesn't look like the small block ones I see in most illustrations. What kind of information would you guys need to help me determine what mounting kit or bracket I could use to get my alternator moved. March has a $400.00 kit but I didn't want to covert the whole front end of the engine! By the way I have Edelbrock heads if that matters.
Thanks, Bob
Old 03-06-2007, 02:47 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
i had the same problem.ended up with CHP set up and a v belt (still at 7o'clock) changed to a chevy alternator(one wire) and under 300$ for everything . look at my gallery.miladon high flow water pump.clock wise rotation.make sure you have the right rotation for your aplication.
the older i get the faster i was.
Old 03-06-2007, 02:51 PM
pmfranke's Avatar
oh, i have aussie alum heads and i had to elongate one hole a tiny bit on the alt bracket(covered it up with a chrome washer)so nobody knows.
Old 03-06-2007, 08:06 PM
BeasleyRB's Avatar
Thanks PM, I think I will go this way too. I like the alternator being closer to the pulley's with the v belt.
