Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-12-2007, 12:08 PM
Cobra Make, Engine: B&B 302 GT40, T5 5sp, 9"rear end
Default Nose
I just noticed the nose on my car is not quite right. Im posting some photos on my photos but it might not show in these.Its not bad but it is there anyone else have the same thing?
Old 06-12-2007, 01:02 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
my nose is'nt perfect either. hood scoop off center ,tail light off center. right side is low. they say it the way the original was but i dont know.at least they are strong.
the older i get the faster i was.
Old 06-12-2007, 01:22 PM
Not complaining just wondering its not bad. This does seem to be a good strong body if you compare it to others. I am having some trouble fitting the doors but that could just be me everything else is great.
Thanks
Old 06-14-2007, 07:05 PM
Cobra Make, Engine: B&B, 302 Ford crate motor
Speaking of the nose section, make sure you measure the holes for the front bumper carefully. I used B&B's marks and they are a little bit too far apart.
I had to get a clamp to pull the bumper together a bit. Not a problem if you are using the jacking points I guess.
1993 Mustang Cobra
Old 06-15-2007, 03:09 PM
Default Dimensions
I had a lot of body dimension variations. Nose was off, hood scoop etc. Spending a lot of time filling with fiberglass and blending. Regarding the doors look at the previous posts. DO NOT USE any of the B&B mounting holes. Make sure to line up the wheel wells on the tires to get the proper centering. Regarding the doors, hang the hinges and adjust best you can. Remove the 2-3 screws that B&B used to mountthe body under the door and push-pull the body to match the doors. The re-drill and bolt it down. Saves you lots of time and filler.
Old 06-15-2007, 05:18 PM
Thanks, I will try that sounds like a good fix.
Old 06-22-2007, 08:06 PM
Slow Dawg's Avatar
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
Well guys, in B&B's defense, since the mold was splashed off an original, you shouldn't complain to Bryan. You should have complained to Ol' Mr. Shelby about 42 years ago.
Nonconformist. Can't handle a real job.
Old 06-22-2007, 08:12 PM
double ugly's Avatar
When we re-assembled my Hi Tech, we discovered that the body wasn't symetrical. It was splashed from CSX 3151. Trunk lid license plate bezel off 1/8 " to the left, fenders in front were different etc. That's the way they were.
John
double ugly
Old 06-28-2007, 10:52 PM
MacGyver's Avatar
Cobra Make, Engine: B&B 5.0 roller W/carb & T-5 WC
In an embarrased testament to the strength of the chin of the B&B I bumped the lower chin fairly solid on a parking curb the other day with hardly a scratch. I did have to loosen the brace to frame bolts & relieve the tension induced by the nudge. Of course there was a stranger there to witness the event & my 20 year old son asking me "what are you new"? He has driven the Cobra many times without incident........I will never live that down
"Oversteer is when the passengers are scared. Understeer is when the driver is scared."
