Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 06-17-2007, 06:03 PM
Cobra Make, Engine: B&B 302 GT40, T5 5sp, 9"rear end
Default Ford 9"
I have a 9" but it looks like the yoke is from a 8.8 flat bolt on no u-joints in the rear so did some come this way? My dum ? for the day.
Old 06-17-2007, 08:34 PM
Rick Parker's Avatar
Yes, I believe some of the Lincolns and Large Ford Cars had this type of pinion flange.
Old 06-18-2007, 10:58 AM
A lot of the big fords and explorers used a flange type connection. You can order the right yoke from Summit or Jegs. Check you gear ratio. Mine was so tall I had to replace the ring and pinion along with the yoke.
Old 06-18-2007, 11:11 AM
427sharpe's Avatar
I think all of the flanges are the same on this type. Try a wrecking yard for a rear driveshaft flange from a MK IV Lincoln with a 460 and you will get the round flange that bolts to your pinion flange and it will be set up for the large u-joint. It would not hurt to make a good sketch of the pinion flange w/ measurements to make sure thet the DS flange will work. If there is a tag on the differential, post all the numbers and I can find out where it came from and maybe steer you the right direction!
Old 06-18-2007, 11:18 AM
Karl Bebout's Avatar
Mine has the flange. I've never heard that there's any advantage to the yoke or flange style. To me, the flange style LOOKS stronger, but I don't really know. I did discover that I had a 9 3/4 ring gear that I think was only used in one or two years of Linclons. (the housing is the same) I changed out the third member, installed 3.50 Richmond gears and a Powertrax system that works great. I do get the occasional click on some turns, but not nearly as nasty as a locker and it certainly does drive both wheels nicely. No clutch slippage like with a posi.
Karlos
