Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 09-18-2007, 12:31 PM
Default Ididit column and Horn
How do I get the horn working with the Ididit column and the GM steering wheel adapter with center horn push button? Do I need to purchase a switch that inserts into the column?
Thanks,
Corey C
Old 09-18-2007, 04:35 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
There is a 1/4" spade connector that the black wire from the opposite side of the horn relay runs to.
When you press the horn, it connects to ground.
Find the 1/4" spade connector and put an Ohm meter to it and ground, press the button. I should read from infinity to near zero as you press the horn button.
The horn should sound when the wire touches any ground.
Hope this helps.
Old 07-08-2012, 07:22 AM
Default Horn
It has been a long time but I am now back at it. Still have not fixed the horn issue. I understand it makes a ground to sound the horn but when I look in there a have a brass screw on the back of the center cap and 3 holes in the center of the column (one which looks like it has some sort of connector inside) How exactly is the gound made and am I missing some kind of connector in there?
Thanks,
Corey
Old 07-08-2012, 03:44 PM
Cobra Make, Engine: B&B, York 351W (Work in Progress), 07 Shelby GT # 0767, 09 Shelby GT500, 09 Shelby GT500KR #440
I had to run a ground wire to the outer steering column casing. I used the steering column fasteners keep the ground wire attached to the steering column casing.
Old 07-09-2012, 12:21 PM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
You have to buy a horn contact from an earlier gm vehicle. I believe a mid 70's part will work. I have seen them for second generation Cameros.
Here's one on fleabay.
http://www.ebay.com/itm/67-81-CORVET...item337772eb59
Just google "GM horn contact" and you'll come up with all kinds of hits.
Old 07-09-2012, 07:36 PM
Thanks...that's just what I needed. One more thing crossed off my list.
