Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 02-25-2008, 02:17 PM
MacGyver's Avatar
Cobra Make, Engine: B&B 5.0 roller W/carb & T-5 WC
Default Headlight Gaskets
Does anyone use a rubber gasket between the headlight assembly and the body on the B&B? When replacing a headlight I noticed the ring makes damaging contact with the body. At the time since this was my first experience I thought that was the way they were. After being exposed to several other Cobra's I noticed most of them have gaskets. Here is my main Questions. Does B&B make a headlight gasket? Will the Finishline one fit? This seems like an oversimplified question but looking at several cars some of the rings have different shapes and I'm concerned with proper outside diameter...Thanks!!!! Matt
"Oversteer is when the passengers are scared. Understeer is when the driver is scared."
