07-24-2008, 08:24 PM
Cobra Make, Engine: B&B, 1969 392w, Tremec TKO
Standard B&B radiator question...
My engine is a 392w that will put out approximately 475 horsepower. Can I use the standard radiator that came with my kit as long as I get enough CFM from my 2 puller fans? Each fan is supposed to pull 3000 CFM at 7.5 amps. Thanks...
07-26-2008, 06:23 PM
Radiator
I don't know what the capacity is of the radiator from B&B.
The 77-78 Mustang II radiators have the brackets and support structure to mount to the B&B front clip. They are also narrow enough to fit inside the body.
US Radiator has a Mustang II radiator that will bolt right up to the B&B brackets and with the bottom outlet pointed up so it can be routed above the frame member. HP. Part # 53160.
http://www.usradiator.com/catalog.htm
Get the 3 pass desert cool model. I have a 460@520HP with a single 2300 CFM 16" fan. Never operates above 190degrees. Make sure you duct the air to the radiator and have a fan shroud.
07-26-2008, 08:33 PM
OK
Boris,
Your 4 core radiator will be fine just be sure you get all the air out of the system. I ran the standard radiator with my 427 for several years. I changed because I managed to get a hole in mine and wanted an aluminium cross flow radiator.
Enjoy your ride.
Clois
"Let's roll"
"Be part of Something Good
08-23-2012, 09:06 PM
NJ
Cobra Make, Engine: B & B
I have to replace my standard B & B radiator. It has given me 11 years of good service. Is it a standard 4 core out of a mustang 77, 78???? Just want to be sure.
04-12-2013, 09:16 PM
NJ
Wow trouble finding a stock replacement radiator.
04-13-2013, 06:18 AM
AL
I replaced a radiator in a B&B last year. It was a copper radiator from the 70's. I called a company in Gadsden, Al and they made me an aluminum radiator that was a drop in for $325.
I have the drawning if you need it.
Dwight
http://www.cgj.com/shop/radiators/an...ance-radiators
04-13-2013, 06:56 AM
Cu?i tu?n vui v? bên nh?ng ngu?i yêu thuong nhé c? nhÃ*.
04-13-2013, 10:31 AM
MN
Cobra Make, Engine: B&B, FR302
Jams,
I have an original B&B Rad I would sell for $150. Went to an Alum but the original was just fine. Let me know if you are interested.
Roger
There are two kinds of people - those smart enough to know they don’t know, and those dumb enough to insist they do
05-29-2013, 10:32 AM
Cobra Make, Engine: B&B Ford FE from Southern Automotive
Need a replacement radiator for my B & B Cobra
The radiator in my car has developed a significant leak and needs to be replaced. Current unit installed is the standard brass that was supplied by B&B. I will consider both brass and aluminum as a replacement. Any help with locating a suitable drop in replacement unit is greatly appreciated.
05-29-2013, 12:56 PM
MN
I have an original Rad from my B&B -- has about 6k miles on it. It's in good shape I will sell for $150.00. Also I replaced the original the direct bolt in from Griffin Alum. is PN 9D-14523-01. It was $625.00 plus ship and all you need to do is bolt it in as it is made for the B&B mounts.
Roger
05-29-2013, 03:17 PM
NFLDMN - Have sent you a PM
05-29-2013, 04:02 PM
AL
aluminum radiator for B&B
I bought one last year from CGJ, cost about $325.
I have the drawing if you need it to order one from them.
Dwight
