Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 01-09-2009, 07:19 AM
Default LeMans Gas Cap
Does anyone know off hand what size hole I need to drill in the body for the LeMans gas cap?
Corey C
Old 01-09-2009, 07:46 AM
Clois Harlan's Avatar
Drill a 3 1/4" hole or what ever the diameter of your threaded base of your cap is (I have seen some that were smaller than others) so be sure and measure. If I remember correctly you will have about a 3/8" to 1/2" edge inwhich your cap is mounted.
Clois
"Let's roll"
"Be part of Something Good
Old 01-13-2009, 05:54 AM
For the life of me I can't figure out how to install this gas cap. I have the metal tubing that attaches to the plastic gas tank, a length of black rubber tubing and the lemans gas cap, base and cover. Am I missing a piece? I assume I need another piece that installs inside the aluminum cap? Does the base of the lemans cap get installed from under the body with the cap screwing into it? If so I would need to cut a 4" hole in the body.
Corey C
Old 01-14-2009, 03:50 AM
lnfletcher's Avatar
This is how I did mine.
http://lnfletcher.homeip.net/66Cobra/gascap.html
