Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 08-09-2009, 06:40 PM
Cobra Make, Engine: B&B, 302 Ford crate motor
Default 10" springs
This is how the 10" springs look. They adjuster nut is all the way down. The wheel to fender clearence is about 1 1/2". There is full supension travel and does it make a difference in driving.
The springs are 10GSF 350 from QA1. The 350 is pounds of coarse.
1993 Mustang Cobra
Old 08-10-2009, 10:09 AM
Clois Harlan's Avatar
I think you are pretty much right on the spot for the springs if you are running a small block. If you are running an FE then you might want to go up to a 450-550# springs. The larger number would be if you are racing and that is just a guess because you would really need to have the weight at all four corners to determine the correct spring rates if you just wanted to go neutral.
"Let's roll"
"Be part of Something Good
Old 08-10-2009, 01:17 PM
I can not tell you how much better the car is with the 10" springs. It is indeed a small block. A 302 Ford crate motor with a Holley dual pumper. It is certainlt a blast to drive.
What are your thoughts on the rear springs? I have not compressd them nearly as much as I had to the original B&B front springs.
1993 Mustang Cobra
