| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
01-10-2010, 08:21 PM
Stolen Avitar
GA
FE Valve Covers in the BDR
Well now that I've got beautifull headers it's time to get to work on this puppy.
When I first ordered the car from Jay at Vintage he told me that some VCs won't have clearance and now I can definately add H/M VCs to the "won't work" list. That kind of sux just because they would be something cool that you don't see on a Cobra very often. Plenty of room on the passenger side but none on the driver's side.
So lets get a dialog started:
what works?
what doesn't?
of those
what's cool?
what's lame?
I know, lots of opinions here (which could be dangerous  ) but no time like the present to look at any alternatives. I aired this question over on the FE forum and have been getting feedback there as well.
Steve
01-10-2010, 10:16 PM
La.
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
glue that plastic in the first pic down really well to the gasket face .....
Pull a gear .... drop the hammer .... and enjoy the Drive !!
01-10-2010, 10:20 PM
CA
sooooo Can you slide a business card in between the VC and the steering collumn >?
01-11-2010, 04:00 AM
Stolen Avitar
GA
Nope. The vc won't sit any closer than about 1" to the head without resting on the steering shaft.
01-11-2010, 05:31 AM
Backdraft Racing Dealer
CT
Based on this pic:
It looks like the H/M valve covers are the same as the Roush style for the FE (except Roush welds the nice wire looms on the covers, a detail which adds considerable $ to the cost and is often lost by the avg. spreadsheet price comparison shopper, but I digress  ).
So we know it can all fit:
Please take a side shot of the car so I can see where the sidepipes are situated vertically out the body cuts. Also, install your carb and intended air cleaner setup to record vertical space there. Finally do you have the solid bushings on the motor mounts or did they use the factory rubbers?
01-11-2010, 10:46 AM
CA
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Yikes, it looks like changing spark plugs on that baby is going to be a biatch.
Chris
01-11-2010, 12:12 PM
ont
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Could you move & remount the support further down the shaft?
It looks as if the clearance increases as you go down the shaft.
Make a bracket to mount @ the original location & mount the bearing further down?
Or something else you can re-locate it to?
Craig
01-11-2010, 03:49 PM
Impressive work cashburn!!!
01-11-2010, 04:24 PM
CT
Thanks, that is Brian's art... I just take the pictures
01-11-2010, 04:58 PM
Stolen Avitar
GA
01-15-2010, 12:23 PM
fl
Cobra Make, Engine: Backdraft #985 Custom Pro/ Street Race Car, full cage, dry sump 427W and G Force T-56 Fully Street Legal!!
Jay, I notice in your pictures, that the valve cover is not parallel to the footbobx/steering shaft, but Steve's shot appears more so. Has there been a footbox angle change in the molds?
Life is short, live like you mean it!!
Live every day like it's your last. One day you will be right!
01-15-2010, 03:04 PM
CT
I believe it is simply the angle of the photo/perspective mixed with the fact that we have the engine sitting a bit higher. I am trying to locate another shot to demonstrate this, but too many photos...
01-15-2010, 04:26 PM
CA
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
01-15-2010, 04:30 PM
La.
