Old 09-27-2011, 03:05 PM
Cobra Make, Engine: BDR, 302
Default Dip stick tube for late 302
While checking out everything after having the BDR on an extended road trip, i noticed that a small piece of the bracket on the dip stick tube had broken off. The tube was almost falling out. Apparently the u-shaped bracket never fit down completely on the header bolt and caused the bracket to break. The bracket had the number 111481 on it. I think this is the stock tube but i have been unable to locate one. It is a push in the block tube. Any suggestions? Anyone use the Lokar dip stick/tube. Thanks.
Old 09-28-2011, 12:53 PM
52chevyred's Avatar
Cobra Make, Engine: Street Beasts 302 HO
I'm using the Lokar stick on my '90 302 engine. Had to "modify" the bracket a little, to "center" the tube between the header tubes. Looks great! I'll try to take a picture.
52chevyred
Old 09-28-2011, 01:09 PM
Double post.
Old 09-28-2011, 01:11 PM
Thanks for the info. It would be great to see a pic of it. Did you have any problems getting it into the block or with the length of the dip stick?
I'll order one today from Jegs.
Old 09-28-2011, 03:07 PM
52chevyred's Avatar
I just posted two pictures in my gallery: I couldn't get them to load here. I hope this helps.
52chevyred
Old 09-28-2011, 05:36 PM
Great pics! I placed my order tonight. The old tube feels very loose so I hope I don't have problems getting it out of the block and the new one in. Thanks!
Old 09-29-2011, 05:30 AM
52chevyred's Avatar
It shouldn't be a problem. The Lokar has a "locking feature" that keeps the stick in, until you push down on it: neat feature and the stick looks great too.
52chevyred
