November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-16-2010, 11:51 AM
WPa Cobra's Avatar
Cobra Make, Engine: BDR 828
Default Easiest way to replace brake switch
Hi Folks...anyone have the easiest way to remove/replace the brake switch on the master cylinder ? Remove the side SS vent? Special wrench?
Thanks
Old 11-16-2010, 12:23 PM
Cobra Make, Engine: BDR, 302
I just used a pair of channel locks to take off the old switch. I didn't have to take off the side gill. It is easy to get to. I used a (I believe was a 1" socket) socket and ratchet to put on the new one. You have to tighten it quite a bit to keep it from leaking. It didn't take more than 15 mins.
Old 11-17-2010, 05:31 AM
I am assuming that you mean the stoplight switch. You can remove it gently with channel locks. Just open the hood, no removing anything else. Don't crush it. use thread tape when installing the new one. You may have to take the old one to the parts store to match it, Advance Auto parts has them. Have the new one ready to go if you can and you will lose very little fluid or use a pipe plug in the MC when you go get the part. I have replaced mine twice. Heat from the headers will cook them. Kind of a poor design.
Old 11-17-2010, 06:04 AM
Cashburn's Avatar
Backdraft Racing Dealer
Taken from backdraftboys.com post by "BillW":
I replaced my switch last week end, it is a 10 minute job (part was about $17 at NAPA - Echlin p/n SL147) Here is a step-by-step: take a pair of small channel locks and unscrew the switch to point where it is hand removable. Place a small plastic cup under the old switch and then remove while quickly inserting the new switch. A minimal amount of brake fluid will come out. The new switch is tightened and the wires re-attached.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 11-18-2010, 10:06 AM
WPa Cobra's Avatar
Thanks Folks......will follow the advice, thanks
Old 11-19-2010, 02:26 PM
Cobra Make, Engine: BDR 293 gray W/Silver Smedling 351W
Nut's and I remove the engine to get to the switch. good tip guy's
Rich
Old 12-06-2010, 11:37 AM
WPa Cobra's Avatar
Hi Folks...well nothing is as easy as it seems. The brake light switch was installed by a gorilla I think, so....remove the side vent, get the big wrench, got it out...new switch in..works !!! But since the vent is out, polish it up...oh, the inner body needs some touch up paint while Im here....now the right side vent needs polished, paint inner body...so the 20 min job...3 hours ! But, its always a pleaure to spend some time in the garage !
