Old 03-05-2011, 02:29 PM
Dtgl1's Avatar
Cobra Make, Engine: BDR #181
Default Tach problem...Need Help!!!
It just started yesterday while I was driving, the needle just swings wildly from 0 to 7000. No pattern that I can see. At idle it sometimes goes to 0 and sometimes moves.
Tach is a Revolution gauge.
Anyone got any ideas? Thanks
Old 03-05-2011, 03:17 PM
RET_COP's Avatar
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
What kind of ignition do you have?
Does you in dash tach act the same way?
Check all your wire contacts.
Lou
Old 03-05-2011, 03:30 PM
gsharapa's Avatar
Check to make sure you have a good solid ground on it.
Gary
CAV GT40
Old 03-08-2011, 09:20 PM
Rwillia4's Avatar
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Yep check the ground.
Old 03-08-2011, 09:30 PM
twobjshelbys's Avatar
Does the tach pick up from an electronic ignition box (MSD)? If so check the tap. They usually clip it on with some kind of clamp-on connector that makes a "pin prick" connection through the insulation. It can separate from vibration.
Tony
CSX4005LA
