Old 08-04-2011, 06:40 PM
Cobra Make, Engine: BDR, 302
Default Back Draft Front wheel bearings
I have BDR 226 with 5200 miles. I have had problems with a slight popping sound when I'm turning right into my drive way at slow speed. I changed the front sway bar bushings which didn't help. But I found the problem. The front driver's side wheel had a small amount of play and popped when I pulled laterally on the top of the wheel.
Both wheel bearings have gone bad and have been replaced. Problem solved. Has anyone else experienced this problem? I find it hard to believe they would go bad after so few miles. Thanks.
Old 08-04-2011, 09:21 PM
bobcowan's Avatar
If wheel bearings are not installed correctly, they'll wobble and only last a few thousand miles. People that owned old mustangs (like late 60's) learned to adjust the wheel bearings fairly often.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
