December 2025
Old 10-06-2011, 06:09 PM
Cobra Make, Engine: BDR #143 351w
Default Turn signal lever
Just took the cobra out for the first time in about 6 months and noticed the turn signal lever pointing straight down, 6:00 position. The assembly is loose as a goose. Before I go taking the steering column apart, I thought someone might know an easy way to tighten it, ie. set screw or something to that respect. Thanks in advance for any info.
John
Old 10-06-2011, 06:37 PM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
Only one solution to this problem. You need to sell the car fast. I'll give you $25K sight unseen.
Just kidding. This is easy to fix. Just get underneath the column and tighten the set screw after you reposition the lever. I had to do this a couple of times when I had my car. I am sorry that I can't tell you the exact procedure, because I no longer have the car. But, some of the other current owners can certainly give you the details.
SkipB
Old 10-06-2011, 06:44 PM
Thanks, Skip
Make it $30,000 cash and its yours.
Old 10-08-2011, 08:34 AM
I assume you are kidding like I was? I am in the market for another Backdraft.
Old 10-08-2011, 12:10 PM
Cobra Make, Engine: BDR, 302
On 226, there is a small Allen (metric) set screw on the top of the turn signal lever housing. This is if the lever is on the right side.
