Old 04-05-2012, 02:46 AM
WPa Cobra's Avatar
Cobra Make, Engine: BDR 828
Default BDR weight and CG
Hi Folks
Any close idea what our BDR's weigh w/out driver? 2500 #?
Also, any idea on CG location?
Setting up an enclosed trailer, looking for starting points.
Thanks
Tony
Old 04-05-2012, 07:42 PM
Cobra Make, Engine: backdraft racing #470 427sb
Tony What is CG? Center of Gravity? just wondering and trying to help,sorry otherwise I believe our BDR weighs about that i have never scaled mine sorry. I have a 24 foot enclosed trailer rated for 10,000lbs don't even feel car inside trailer while driving Tim
Old 04-07-2012, 04:25 AM
WPa Cobra's Avatar
Default Thanks
Thanks Tim
Yeah>>>CG is center of gravity. I have a 20" trlr that Im going to load first time this weekend. Was looking for a good starting point for first position before measuring tongue weight. BTW, do you have any concerns while rolling into trlr ? Is being hooked up to tow vehicle good enoufgh or do you put jacks under rear of trlr to asist ?
Old 04-07-2012, 06:01 AM
lovehamr's Avatar
Stolen Avitar
If it helps, I put the front edge of the Cobra's door right between the axles of my trailer. That may not hold true for your trailer, but it's a place to start.
Steve
Old 04-07-2012, 09:01 AM
WPa Cobra's Avatar
Thanks Steve ! Sounds good....
Old 04-08-2012, 04:35 AM
Tony I always am hooked to the truck when putting a car into the trailer. I too put the door between the wheels. I don,t have any issues being too hitch heavy. The tie down's in the floor are also spaced equal. Good luck. Tim
Old 04-08-2012, 07:14 PM
Cobra Make, Engine: backdraft racing 302 ford
M I have # 84 and its weigh is 2450LBS with out driver
ED
Ed
Old 04-09-2012, 12:16 PM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
ditto what thunder1 said about wt.... 2450# on the scales...302 alum. heads, carb, t5 with 15" wheels and all fluids and 1/2 tank of fuel. CG????from jacking it up on the side...my guess would be right around the leading edge of the door.
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
Old 04-10-2012, 02:24 AM
WPa Cobra's Avatar
Well, you are all correct ! Started with leading edge of door between axles. Had to move forward about 8 inches to achieve 12% tongue weight. Trailers drives out very smooth....thanks guys !!!
Old 04-10-2012, 03:58 AM
lovehamr's Avatar
Stolen Avitar
Hey, we're here to help man! LOL!
