Old 09-02-2012, 08:27 AM
Default Gas Pedal
Hi, new to BDR ownership. My car (#88)'s gas pedal has a very long travel & the return is very weak, even with 2 springs on the carb. Was there a change to the gas pedal/throttle cable design in later cars?
Any help is appreciated.
Old 09-12-2012, 12:52 PM
Hank Steckel's Avatar
Cobra Make, Engine: BDR #258, British Racing Green/Silver Stripes, Gray Int., 351W, T5
My guess is you ought to move the ball joint on the carb throttle arm to a spot closer in to the shaft. That would shorten your gas pedal travel. You may need a stronger spring(s) as well. Try moving where the cable connects to the carb throttle arm 1st.
Hank Steckel
BDR #258
San Diego
I never make mistakes. I thought I did once, but I was wrong.
Old 09-14-2012, 05:35 AM
6t8stang's Avatar
Cobra Make, Engine: BDR#436 - 351W - 450HP / 429TQ
Don't forget to make sure you have a pedal stop as well...adjusting so the floor/firewall is a stop is OK.
Eric
Old 09-14-2012, 01:11 PM
6t8stang-
How do I do that? The pedal is mounted on the trans tunnel, I'm not sure how to build in a stop off the firewall.
But the travel on my pedal is way too long. So to get WOT, I need to figure out how to shorten the entire throttle operation.
Rate This Thread:
