Old 11-03-2013, 01:13 PM
rpatton3's Avatar
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Default Travel jack for trunk of car
I think I have read a jack from a Taurus or 300ZX will work on a BDR. Anybody with ay advice is welcome to share it with me.
Thanks,
Russell
There were no atheists in the foxholes.
Old 11-03-2013, 01:16 PM
Club Cobra Member
Cobra Make, Engine: NAF 427
I use a jack from a 1990 ish Nissan 300ZX Twin Turbo. I've posted this before so search it. Nice aluminum piece, low and light.
Greg
Old 11-03-2013, 01:39 PM
Cobra Make, Engine: superformance 1022
Russell go to a boneyard and find a Jeep Liberty. Jack is small, lightweight, and has a carrying case. It works on my SPF so it should work on a BDR.
Tom
Old 11-03-2013, 01:51 PM
Harbor Freight has a nice little blue aluminum FLOOR JACK that goes on sale for about $60.00 that is compact, light and safe to have on board. Bungee it in there and you will be just fine.
Old 11-03-2013, 01:55 PM
rpatton3's Avatar
Thanks to all of you. At least I have some options.
Old 11-03-2013, 02:24 PM
mrmustang's Avatar
Gold Star Contributor
Thumbs up
Thanks,
Russell
Mid 80's Honda or VW jack, comes with a fold up handle, and a carrying case......
Bill S.
Old 11-04-2013, 02:56 PM
rpatton3's Avatar
This is great.
Thanks!
Old 11-04-2013, 03:46 PM
mln385's Avatar
Cobra Make, Engine: BDR
I have one of these and it works great compact and has a case. >>>>>>
1 Ton 2 200 lbs 12V Electric Scissor Jack Auto Car Lift | eBay
Old 11-04-2013, 05:13 PM
I just bought a 90's mustang scissors jack from eBay for $25, delivered. Still deciding whether I should just throw it in the tool bag, or make an aluminum mount for the trunk.
Old 11-04-2013, 05:56 PM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
I just sent one of those back for a refund of my money. While lifting the front end of my SPF the screw snapped and my car instantly crashed to the floor. Thankfully the only damage was the destruction of the jack. Be careful
Ted
Old 11-04-2013, 06:46 PM
If you don't have a spare tire, why would you ever need to jack up your car on the road?
Old 11-04-2013, 07:09 PM
rpatton3's Avatar
To get out. I use a wheelchair and need clearance under from under frame.
I have a patient lift to pick me up. We never go far from home.
Old 11-04-2013, 09:23 PM
Guys, don't forget that if your car has a flat, it's going to be about 2" - 3" closer to the ground sitting on the rim. So your jack is going to need to be less than 3" tall!
Old 11-05-2013, 07:13 AM
rpatton3's Avatar
I may need tow truck wrecker with a boom to get me out!
Old 11-05-2013, 07:44 AM
Yeah, but if you jack the back of the car up high enough, the front wheel comes off the ground too, and vice versa. Now if both tires on one side were flat, then you'd have a real problem -- whether you had a spare or not. Jack it up from the differential, I suppose.... I do carry two big cans of Fix o' Flat and a cheap little 12v air compressor (that has blown up more basketballs than it has tires).
Old 11-06-2013, 11:19 AM
rpatton3's Avatar
I guess my 17" wheels will save me an inch of clearance.
We use a couple of short ramps to get patient lift under frame.
They should go into trunk, I guess.
Thanks for the input.
Old 11-06-2013, 12:46 PM
wrogers55's Avatar
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
I'm with Patrick on this one. With no spare, why would a jack be needed? Rubber plug kit and a 12V mini compressor in the tool bag will solve almost everything but a cut or a tire that pulled away from the bead, but a jack isn't going to help that either. Might just be me, but seems strange.
Wayne Rogers in Hideaway, Texas
Old 11-06-2013, 01:31 PM
Registered User
Cobra Make, Engine: S C Motorcars
I have met the OP and he is the most diehard Cobra owner that I know. He is wheelchair bound since his college days and still goes for rides in his Backdraft. He uses a patient lift (kind of like a cherry picker to set him in the car). More frame clearance is needed for the legs of the patient lift to pass under the frame of the car, hence the need for ramps or jack to get the needed clearance.
My hats off to you Russell.
Lester
Old 11-06-2013, 02:46 PM
Cashburn's Avatar
Backdraft Racing Dealer
Russell,
Did not realize you needed something along those lines when you got the car. But it would be possible to install an onboard jack system that could lift the car enough for your patient lift to clear. They are common on race cars etc....
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
