Old 07-22-2014, 11:24 AM
Cobra Make, Engine: Backdraft #832
Default Clutch Slave Cylinder Bracket
After replacing the fluid in the clutch I noticed that the bracket holding the slave cylinder moved as the clutch was depressed. I removed the bracket and push rod and replaced it with a custom bracket made from 1/4" 4130 steel. I purchased from Rosenhill their adjustable push rod. This gives me much more control over the clutch operation. I had the original bracket duplicated and manufactured using a water jet to cut the steel and then bent to the exact spects. If interested contact me at jimbo01@embarqmail.com
