December 2025
Old 09-08-2014, 04:03 PM
Cobra Make, Engine: backdraft racing 302 ford
Default limited-slip differential
I know backdraft sales the lsd but does any one know the percent of lockup?
any one have a good used one for sale? should I get a 3.46 or a 3.64 I have a 302 engine with a 650 Holley.
ED
Ed
Old 09-08-2014, 04:51 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
What duration of cam at .050. If you have a 5 speed what is the OD ratio. Most likely 3.64.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Old 09-08-2014, 08:01 PM
Cashburn's Avatar
Backdraft Racing Dealer
What trans? You should go 40% no higher.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 09-08-2014, 09:40 PM
Cobra Make, Engine: Backdraft, SBF 351w (463 CI)
ED
Its a factory LSD which i believe is 25% lock up (no added clutches). Call Dan at diffsonline he can fix U up with what ever u want. Stay away from ROB at percision gear .
I would go with the 3.64
Mark
Old 09-09-2014, 04:01 AM
tremec 3550 with stage 2 trick flow cam at 70mph it is running 1800rpm in 5th gear i need more rpms for my carb to help with the loading up.
Thanks for the help in advance
ED
Ed
