Like Tree1Likes
  • 1 Post By cbreez
Old 10-22-2014, 01:19 PM
Cobra Make, Engine: Backdraft Racing 427 SC
Default Body adjustment over rear axle ?
I noticed there is about 1/2 inch less of fender hangover on the driver's side over the rear wheels. Can the body be moved over the rear axle to have each side hangover the wheel equal ?
Old 10-22-2014, 06:09 PM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
there is an adjustment nut (for a spanner) on the top spring seat, but level the car by the frame, not the body.
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 10-22-2014, 08:14 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Do you mean side to side?
" It ain't no big deal"
Old 10-23-2014, 06:11 AM
Yes, I mean side to side.
Old 10-23-2014, 06:18 AM
Well, that being the case, if you had a solid axel you would adjust the panhard bar to line things up. But with your Backdraft you have an IRS which is a different story. The Backdraft guys should chime in and hopefully be able to help you out.
Old 10-23-2014, 06:31 PM
It sounds like you talking about suspension and alignment. I think this has to do with how the body mounts to the frame.
Old 10-23-2014, 07:07 PM
The body of a backdraft is factory installed..
Old 10-24-2014, 05:48 AM
MOTORHEAD's Avatar
The adjustment I was referring to is the ride height, which also raises/lowers the body and chassis with reference to the ground. The important thing is to have your ride height correct, and without doing a corner balance, the only thing to do is check ride height, adjust if necessary, and no, there is no adjustment to the body with reference to the frame,
Old 10-24-2014, 08:55 AM
Thanks for the reply. It is not that much out. I will leave it as is.
Old 10-24-2014, 10:19 AM
Cobra Make, Engine: csx4163 full comp alu. body
I have seen some make adjustments with the wheels, spacer, machine off material on backside of wheel if enough material is present. Keep in mind stud length if you have pin drive wheels.
Old 10-24-2014, 03:59 PM
RT3_1350's Avatar
Cobra Make, Engine: Backdraft RT3 #1350 427
Eedeu...
My Rt3 was the same as yours with 1/2" lower clearance over the driver side rear tire. My tires are the taller 295s. So I just finished adjusting it. Needed to upgrade the shocks which are taller and will allow you to crank down the spanner nut on top of the spring. There are several steps but is an easy fix. Frame is still level in back and wheel clearance over the tire is equal now. Custom Cars should have done that but didn't. If the tall tires hits the body it runs risk of cracking paint. Ideally you want at least 2 finger clearance over the tire and body.
Old 10-24-2014, 04:03 PM
RT3_1350's Avatar
Eedeu...
Old 10-27-2014, 04:50 PM
If you fool around with Ride Height, it should be measured with the driver IN the seat or...use masonry blocks which weigh 40 lbs. each and use the appropriate number of blocks placed on the floorboard and drivers seat to measure! In addition, the sway bars should be disconnected when setting height to eliminate any preload.
A 200 plus lb. driver equals about 10% of the total B/D weight so it's important.
mln385 likes this.
Old 10-27-2014, 07:55 PM
Dwight's Avatar
Smile
I think it would easier to use bags of sand from Lowes. They weight 40 lbs each and are plastic bags. You can sit them in the seat with a beach towel to cover the seat.
Dwight
