Old 10-29-2014, 02:46 PM
Cobra Make, Engine: Backdraft
Default Backdraft Coyote questions
Backdraft recommends that you use synthetic oil after you have 1,000 miles
on your car. Can someone tell me why this is the case? Also,how many quarts
are needed when changing oil and filter?
Much thanks
Old 10-29-2014, 03:48 PM
block honing process for cylinder walls creates horizontal "grooves" this is necessary to hold oil. Theory is synthetic is to slippery and instead of the cylinder walls wearing in / taking the peaks off the grooves the synthetic is to slippery to wear in and it rolls/smears the peaks over and the rings never seat. I would give it 10k miles, that being said with all today advances in engine manufacturing I am sure the bit OEM have overcome this issue.
Old 10-29-2014, 04:00 PM
Grey 65's Avatar
Originally Posted by Rjscharer View Post
Backdraft recommends that you use synthetic oil after you have 1,000 miles on your car.
It is dependent on the engine. Once you know what your engine is then go with what the engine builder/manufacturer says, NOT with what Backdraft says.
See response from madmaxx.
Also,how many quarts are needed when changing oil and filter?
Much thanks
No one can tell you what type of oil, what type of filter or how much oil without you first providing what your engine setup is (stock 5.0 pan, dry sump, etc, etc. Once you know what your engine setup is then go with what the engine builder says, NOT with what Backdraft says.
Kevin....
Old 10-29-2014, 04:18 PM
itstock's Avatar
Gold Star Contributor
Backdraft doesn't build or install engines, so anything they state about engines is pretty damn irrelevant.
Old 10-30-2014, 12:18 PM
Cobra Make, Engine: Backdraft #832
Call Ford Motor Racing and they will give you brake in spec. for your engine. I did.
Old 11-10-2014, 02:07 PM
BDR1222's Avatar
Cobra Make, Engine: BDR, Coyote 5.0 (Sold to Justin in Burleson) working on #2
Ford says 5w-20
