November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-26-2015, 01:52 PM
Cobra Make, Engine: 1963 Corvette Grand Sport Coupe. ZZ502FI. 502 HP
Default Tire pressures?
What cold tire pressures are you owners running? Same on all four or? With the light weight I would think max 28psi cold but wanted to see what you have found to be the best grip and handling psi. Thanks
Your ride should not be to get from point to point. It should BE the point!
Old 04-26-2015, 04:27 PM
Cobra Make, Engine: Superformance #522
My settings are 18 street...26-28 track/autox. 275/35/18 and 315/30/18 Nitto NT01s. Setting above 20(for street) on these tires has less than full tread contact.
Old 04-26-2015, 08:08 PM
bobcowan's Avatar
Street tires start at around 1 psi per 100 pounds of vehicle weight. That varies a bit, depending on tire and wheel combo. But 22-24 psi on each corner will put you in the right ball park.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 04-27-2015, 07:01 AM
Very good info. The car has oem wheels and tires, and weighs around 2400 lbs. Thanks!!
Old 04-27-2015, 12:03 PM
FatBoy's Avatar
Cobra Make, Engine: Kirkham #523, 427 S/O
I'm running 28psi on Avons.
Paul
Old 04-27-2015, 01:31 PM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
26psi on Avons, very even wear. Curb weight=2400#'s.
Dave
Old 04-27-2015, 01:35 PM
kevins2's Avatar
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
28 in the front; 26 in rear. Running 15" 235's front; 295's rear.
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
Old 04-27-2015, 01:50 PM
Thanks guys. These all seem what I kind of figured and great info. Sounds like the sweet spot is 26-28 PSI
Old 04-27-2015, 02:50 PM
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
I got virtually perfect wear out of two sets of Avons running about 22 at all four corners. At the end of the tire life, there was not spot on any tire that was more than 1/2 mm different. But I suppose driving style plays a significant role. Run some gravel roads and then look to see where the dust is.
Old 04-27-2015, 06:42 PM
Start out on the high end of the range and try lowering them a pound at a time until you stop loosening fillings after hitting a lane marker.
Jim
