Like Tree2Likes
  • 1 Post By Bernica
  • 1 Post By BADSN8K
Old 08-02-2015, 08:36 AM
itstock's Avatar
Gold Star Contributor
Default Low profile/drop down air filters
What is everyone using? I need to shave off about a 1/4" from my current filter and want something that looks and flows decent in the drop down style, preferably oval.
Old 08-02-2015, 11:16 AM
cycleguy55's Avatar
A good starting point would be for you to describe what you currently have, including engine, intake manifold and the current air cleaner / filter assembly.
Brian
Old 08-02-2015, 12:03 PM
itstock's Avatar
I am looking for a drop down/low clearance air filter. I currently don't have one of them.
Old 08-02-2015, 12:16 PM
DWRAT's Avatar
1/4"??? Maybe you could trim the base plate flange where it touches the carb.
this is assuming you have at least a 1/4" clearance between the top of carb and the lower filter plate.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 08-02-2015, 12:22 PM
itstock's Avatar
The filter in it can't drop down anymore, it's against the carb as is, but A larger filter would clear, ideally, I guess I would like an oval drop base. But I can't seem to find any oval dropped bases, all are self made....which is an option. I am just trying to button things up though.
Old 08-02-2015, 12:25 PM
itstock's Avatar
I guess another option is just trimming this filter where it is hitting the carb in the front and back, as others have done.
Old 08-02-2015, 01:40 PM
cycleguy55's Avatar
9" K&N filters are available in a variety of heights (e.g. 2", 2.25", 2.375", etc.) - you could go to a lower filter.
Brian
Old 08-02-2015, 03:06 PM
Here is one, an expensive one.
MJB Engineering - Performance is our Specialty
Bill
Old 08-03-2015, 03:04 PM
itstock's Avatar
The current filter already loses 40rwhp, so I do not want to switch to a filter with even less surface area.
Thanks for the link! For some reason google didn't come up with that one.
The turkey pan wasn't that far off in price either.
Thanks for the replies!
Old 08-03-2015, 03:26 PM
Dimis's Avatar
Here's the idea that I stole.
The example is for a tunnel wedge intake but can't be adapted to others.
Tunnel Wedge With K&N Top Filters
Basically a drop down base plate, that allows you to find a couple extra centimetres.
Same vendor also manufactured and supplied mine, an after a bit of home customisation to fit. Job was done.
I'm pretty sure many others could fab them up too, they don't look all that complicated
Good luck with it.
Old 08-03-2015, 03:36 PM
Bernica's Avatar
Senior CC Premier Member
Wow! Nobody mentioned my 9" low base..I'm hurt!
There are already old threads about it.
You can get it here as a complete kit. I make the base plates (low as you can go) and Mickmate is selling the whole kits. Several guys using them.
Not trying to sell you anything. Just thought I would make you aware of another option.
MAXX Air System MAXX Air System [427 289 CSX CCX KMP ACE HT SPF] - $275.00 : Acton Custom Enterprises, Custom Metal for Cobras
Dimis likes this.
Old 08-03-2015, 03:40 PM
DAVID GAGNARD's Avatar
I know your looking for an oval drop base air cleaner,but Jegs/Summit both have round drop base air filters,I used one with a 1.5 inch drop base on my 65 Mustang with no problems......
DAVID GAGNARD
Old 08-06-2015, 01:12 PM
itstock's Avatar
I ended up using the original setup including the turkey pan. Thanks for the links and suggestions and if I wasn't swayed in to keeping the turkey pan, I would have listened to some of you.
Old 08-10-2015, 03:59 AM
BADSN8K's Avatar
Cobra Make, Engine: BD 1445 Coyote TKO 600 3.91
Nitros??
Lets see a video of you on your 0-100 and back to 0 run using this...... keeping it straight
Detroit Bill likes this.
