Like Tree7Likes
Old 05-28-2016, 11:56 AM
tocheck's Avatar
Cobra Make, Engine: Backdraft, small block
Default Am I that dumb?
Hey Guys,
New to the forum and 3 weeks into owning my first backdraft. Several times now while filling up it has burped gas back out the filler. The tank was less than half full every time and it has even done it when I have tried filling it slow. Any one else have this problem or is it just me?
Old 05-28-2016, 12:16 PM
Cobra Make, Engine: FFR fat block tko 600 9"
Tank is not vented or not enough. Air has to go somewhere!
If aliens are so smart, why do they always choose to talk to guys named Bubba?
Old 05-28-2016, 12:40 PM
Cobra Make, Engine: Backdraft 347
check air vent
Old 05-28-2016, 02:24 PM
Kobura's Avatar
Cobra Make, Engine: Backdraft RT3 #1133, Ford Racing 306
There is at least one thread on this problem. You can search for it. Basically, the discussion involves the 3/8" vent line. Check for kinks/blockage. Good luck.
BDR0572 likes this.
Old 05-28-2016, 07:00 PM
csw csw is offline
Cobra Make, Engine: Backdraft #949, 392 FMS
Did it my first fill up...with about 5 teenage boys watching with their tongues dragging the ground...little to say, I felt like an idiot!
Old 05-29-2016, 04:22 AM
Ron61's Avatar
I put two vent lines into mine and that really helped as I never had another burp back.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 05-29-2016, 06:13 PM
On my BDR the vent line pick-off is approx 4" down the filler neck on the onboard side. Standing to the side of the car and relaxing the nozzle against the fill hole points the fuel right at the vent line. What works for me is placing the gas handle aft so the fuel shoots the the fwd side of the filler neck pipe or ensure the nozzle is aimed straight down the filler neck while filling if you have to stand to the side.
Old 05-30-2016, 07:30 AM
tocheck's Avatar
Thanks everyone. Checked the vent line and it looks ok. Spdbrake, my vent looks the same as you describe, I will try your suggestion in the next fill up. And yes I also had a crowd watching as I spilled fuel everywhere.
Old 05-30-2016, 08:16 AM
Do more than look. Blow thru it to verify it's open (both directions)
Old 05-30-2016, 08:29 AM
Mark Brye's Avatar
Cobra Make, Engine: BDR354/FMS392
This is what I do. I just rotate the pump handle 40 degrees or so. That way the gas is not trying to flow into the vent line.
Old 06-03-2016, 03:57 AM
Jethrow's Avatar
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
I find inserting the nozzle into the filler neck as far as I can helps too ...
Tim
FFR Mk4 Roadster
HSV Clubsport R8
Old 06-03-2016, 07:33 AM
tpatodd's Avatar
Cobra Make, Engine: BDR #997, Roush 427SR+TW
I just fill mine slowwwwwly.
I guess we have all had it happen! :P
Old 06-03-2016, 08:20 AM
Millsy's Avatar
Cobra Make, Engine: Backdraft, LS3
I dont have my car yet but i definitely dont want that to happen since i know people will be looking since i have only seen one cobra around here in the last 36 years. So fill it slowly, put the nozzle in far and the position of the nozzle goes which way? I know someone described it above but i still wasnt sure where to position the nozzle. So looking/standing towards the gas filler, is the gas nozzle handle to the left, right or another way. Im definitely learning alot about my car even though its not here yet. Thanks
Old 06-03-2016, 11:57 AM
Stand behind the car, handle over the tail lights, nozzle pointing forward.
Old 06-03-2016, 12:03 PM
Millsy's Avatar
Awesome, now i wont look like a tool with a badass car. I have done it a few times trying to get every drop of gas in my motorcycles over the years which is very dangerous and stupid.
Zeke likes this.
Old 06-05-2016, 05:05 PM
tocheck's Avatar
Success! Thanks every one for the advice, I filled up twice this weekend without a drop spilled. The vent line was clear, just needed to point the nozzle towards the front of the car.
Kobura and Zeke like this.
Old 06-06-2016, 05:37 AM
CBattaglia's Avatar
Cobra Make, Engine: Gary Edwards Racing 460
Filled up twice. Ha, love it! I'm the local Sunoco owners best friend. I can pass anything on the road....but a gas station.
427sharpe, Millsy and tocheck like this.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
Old 06-07-2016, 05:31 AM
Cobra Make, Engine: Proud owner of Backdraft #1609
While were on the subject of fuel, what types of fuel do you use in your Backdraft? We have a Non Ethanol pump nearby, I was considering non ethanol. I too will be purchasing one of these bad boys in the near future! Thoughts?
Old 06-07-2016, 06:35 AM
Just Shell 93 for me. No Sunoco or Gulf stations nearby so sadly no 100+. I also use Blendzall Octane booster (about $40 a gal and it will do approx 3 tankfulls) not that I need it though. I've always been fond of Castor aroma.
This list of Ethanol free stations may help.
Ethanol-free gas stations in the U.S. and Canada
Old 06-07-2016, 11:54 AM
Grey 65's Avatar
Cobra Make, Engine: BDR #888, Keith Craft 408
Fuel is dependent upon your motor, not the car. Backdrafts can have any motor installed in them.
Kevin
