November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree4Likes
  • 3 Post By Winchester67
  • 1 Post By Gaz64
Old 07-10-2016, 10:56 AM
Default Fuse Box
Another newbie question, but where is the Fusebox on our beloved Cobra?
I am still exploring, I assume that battery is under the trunk mat somewhere.
Old 07-10-2016, 10:59 AM
csw csw is offline
Cobra Make, Engine: Backdraft #949, 392 FMS
Fuse box: passenger footbox
Battery: behind driver Taillights and the cover should pull up and off
Old 07-10-2016, 11:01 AM
Thanks for the quick response CSW, much appreciated.
Old 07-11-2016, 05:22 AM
tocheck's Avatar
Cobra Make, Engine: Backdraft, small block
There is also an inline fuse under the dash. Can't remember what it is for.
Old 07-11-2016, 06:18 AM
Interestingly in looking under the passenger dash, I found a metal toggle switch just somewhat hanging there with the label "Fuel SW". I assume it is for an electric fuel pump?
Does anyone use that like a hidden cut off switch?
Old 07-11-2016, 07:12 AM
lovehamr's Avatar
Stolen Avitar
There's also a large one under the pass. fender for main power. Guess how I know that?
BTW Bill, both of mine had the F/P switch mounted in the dash right with the fan switch.
Old 07-11-2016, 01:54 PM
Grey 65's Avatar
Cobra Make, Engine: BDR #888, Keith Craft 408
You mean that big inline 80a fuse that when it blows makes you think your alternator has gone bad?
Kevin....
Old 07-12-2016, 05:54 AM
lovehamr's Avatar
Stolen Avitar
Kevin....
LOL! That would be it!
Old 07-17-2016, 01:21 PM
Winchester67's Avatar
Cobra Make, Engine: Backdraft #91 with 345 HP 302
Mine is on the passenger side, below the dash. A panel swings down to reveal:
Old 07-18-2016, 05:55 AM
Cashburn's Avatar
Backdraft Racing Dealer
You have a very early car or a a Venom.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 07-20-2016, 09:14 AM
Good eye, Jay, as usual! It is #91!
Old 06-02-2018, 02:55 PM
lomdel's Avatar
Cobra Make, Engine: Backdraft RT3
I lost power to the fuel pump today. Checked the fuse box. The fuse marked Fuel pump was okay, but the one marked SP/Batt was blown. Replaced it and she fired up fine. What does the SP/Batt stand for and may I replace that 15A with a 20A?
Old 06-05-2018, 10:29 AM
First to admit I am no expert, but I have over thirty years locked in a mortal battle with Lucas between the cars and the bikes. So for what it is worth, don't up the fuse. Find the problem...fuses are there to keep your wiring harness from burning up. And, frankly, sometimes the harness melts before the fuse blows. I hate wiring problems because I can't see them.
Grey 65, BDR0572 and Trubble like this.
Old 06-06-2018, 08:26 PM
Gaz64's Avatar
Yes, that's for sure. Do not fit a fuse larger than originally designed.
I've seen many electrical fires from larger fuses.
BDR0572 likes this.
Gary
