February 2026
Old 08-21-2016, 08:11 PM
14vision's Avatar
Cobra Make, Engine: Backdraft #964, Roush 427, T56
Default Clutch ?
I have a 6 speed tremec t56 and seem to have a problem. While letting out clutch in first gear I am getting a surging no matter how much throttle I give it. This seems to be getting more pronounced so I am assuming I need some sort of clutch adjustment.
Looking for some guidance from all the smart minds on this forum.
Doug
Old 08-21-2016, 09:22 PM
Gaz64's Avatar
Hi Doug,
It this a clutch shudder, or engine lean surge at part throttle?
Old 08-21-2016, 09:34 PM
14vision's Avatar
Originally Posted by Gaz64 View Post
Hi Doug,
I would say clutch shudder. No engine issues once moving or driving...
Old 08-21-2016, 09:39 PM
Gaz64's Avatar
Hi Doug,
I would say if you have a shudder, the flywheel and or pressure plate is hotspotted or the clutch plate is warped.
If it is a shudder you cannot live with, I'd say it is gearbox out for clutch removal and inspection.
Old 02-10-2022, 09:50 PM
Banned
Howdy Doug,
It this a grip shiver, or motor lean flood at part choke?
www.imybkexperience.com www.mykfc-experience.com www.mybpcreditcard.one
Old 02-11-2022, 11:41 AM
t walgamuth's Avatar
I believe you can get some clutch judder from moisture getting in the friction material. Usually with some use you can get this to dry out.
