Old 09-21-2016, 02:02 PM
Cobra Make, Engine: Backdraft 1048
Default Gas tank replacement
I have a slight leak on the weld seam of the gas tank on my backdraft RT2 any idea how hard it is to replace the tank? Is the fuel pump in the tank? Is it worth trying to get it repaired or just swap a new one in?
Backdraft 1048
Old 09-21-2016, 04:10 PM
If you go the welding route stick with a professional. I've gotten bruises from turning a Austin Healey 3000 tank into a beach ball thinking a couple rinses and 50% water fill and argon running inside will make it safe.
The are some welding companies out there that can do the welding and most are not cheap as they sometimes use total immersion gas (room full of Argon or inert gas).
On BDR:
The tank is easy to drop out and the pump is external unless our running EFI.
Barring that you may give epoxy a shot 1st.
see the amazon link.
[ame]https://www.amazon.com/J-B-Weld-8217-AutoWeld-Repair/dp/B00R2CDUWE/ref=pd_lpo_263_bs_tr_img_2/153-6841469-4398557?ie=UTF8&psc=1&refRID=Z3SKVZSYJ0R5XAWBDBVP[/ame]
Old 09-21-2016, 04:14 PM
mln385's Avatar
Cobra Make, Engine: BDR
Cheaper and safer for a new tank.....
Old 09-21-2016, 04:21 PM
Looks like 4 bolts 2 hoses and a sending unit correct?
Backdraft 1048
Old 09-22-2016, 04:39 AM
mln385's Avatar
And the fill tube connection other than that drain and remove and reinstall new in reverse order.
Old 09-21-2016, 05:00 PM
That should be it
Old 09-22-2016, 07:12 AM
Cobra Make, Engine: Backdraft #832
I removed my tank several times. Not a hard job at all. I had a welder install a bung in the bottom of the tank in the center of rear for fuel pickup. Running fuel injection with a pump that requires gravity feed to the pump this was required. Backdraft used the connection in the center of the tank for the fuel pickup. Want work. Cost $200.00 to get the pump rebuilt by Air Motive. No thinks to Backdraft.
Old 08-26-2019, 06:44 AM
Where's the best place to get a new gas tank for 2007 BDR? I've got a leak on tank weld. Not sure if it's worth pressure test and weld fix buy a pro.
Old 08-26-2019, 07:53 AM
Cobra Make, Engine: Backdraft SBF-302
a $grand should do it
https://www.iconicparts.com/aluminum-gas-tank.html
Old 10-20-2019, 07:40 AM
Can you get a plastic vs aluminum tank and which is recommended? 07 BDR RT2
