Like Tree3Likes
  • 1 Post By am9648
  • 2 Post By bobcowan
Old 06-17-2017, 03:59 PM
bobcowan's Avatar
Default Coyote Engine
Before I started this project, I asked around. Starting with backdraft, and ending with the local dealer. Will a Coyote fit? Oh, sure, it will fit! We have an installation kit for that, no problem.
OK, well, it's really not true. I'm not sure this is going to work out.
It fits down in the engine bay. I had to remove the oil pan so it would fit between the motor mounts. And I had to remove the valve covers to get it in the hole. But it went in.
The hood even fits over the supercharger. Mostly. There's a little bit of interference that needs trimming underneath the scoop, but only about an inch or so. No big deal there.
The engine is in, but there are some real problems. As you can see, the steering column is in the way, and is going to have to be moved. It hits the front corner of the cylinder head, and blocks the dipstick. That's not a real problem, I suppose. I can use street rod parts and move it around enough to work. I think I need to move it up about an inch or two.
But, here's the real issu. And this could be a deal breaker. The alternator. Obviously, the stock part will not fit.
I have ordered a small 80A one wire part; but it hasn't come in yet.
The only way to make an alternator fit here would be to notch the frame rail. Since there's an extra plate welded in, that's an obvious weak spot. Not sure I want to be cutting in to that.
I could raise the engine 1/2- 3/4" for more room here. But then I have to cut in to the hood more.
It also looks like the oil pan will hang below the frame rails a little bit. May have to fab a skid plate for that and the transmission.
This was supposed to be a fairly easy job. Sigh.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 06-17-2017, 07:07 PM
You're making great progress and I'm def envious.
I came across another "flipped" alternator kit for the Coyote.
https://pbhperformance.com/shop/coyo...sory-brackets/
Old 06-17-2017, 09:50 PM
bobcowan's Avatar
That's very interesting! If this smaller alternator doesn't fit, I'll be calling them to see if that will work as a stand alone part. Thanx!
.boB "Iron Man"
Old 06-19-2017, 05:29 PM
pgermond's Avatar
Neutral
I'll be interested to hear how it is changing the plugs........ or anything else.
Phil
http://www.uniquecobra.com/
Old 06-19-2017, 07:19 PM
bobcowan's Avatar
Plugs are easy. It's a hemi head, so the plugs are right on top.
The small racing alternator arrived today. Doesn't fit. Even with moving the engine over 1/2", there's not nearly enough room for an alternator in the stock location.
I sent an e-mail to Power by the Hour to see what they might have available. I like their front mounted alternator mount, that might work.
There's a ton of room on the right side of the engine, where the A/C compressor used to be. If I was willing to pull the engine back out, I might be able to fab a bracket to put it there. Trying to get it done while lying on my back in a tight space is almost impossible.
.boB "Iron Man"
Old 06-20-2017, 09:56 AM
am9648's Avatar
Cobra Make, Engine: SOLD - BDR 1381 Artic White/Silver Stripes / Coyote 5.0
Default coyote alternator
Try installing alt in the reverse position
http://www.clubcobra.com/forums/atta...1&d=1497974067
cdnus likes this.
Old 06-20-2017, 10:00 AM
Karl Bebout's Avatar
Be sure to be on good terms with a local parts store that will not mind if you buy a dozen belts and return the 11 that don't fit.
Karlos
Old 06-20-2017, 11:59 AM
bobcowan's Avatar
I was actually looking at that this morning. Is yours running? Is this working? Any more pictures of this?
.boB "Iron Man"
Old 06-20-2017, 12:10 PM
eschaider's Avatar
Something you guys want to be aware of, if not sensitive to, is the fact that alt's have an internal fan to cool the alternator. The fan and its air flow presuppose a clockwise rotation of the alternator.
Ed
Old 06-20-2017, 12:18 PM
Bob, In your Alternator thread I had posted this pic but there are more in the Mayhem BDR thread. Vintagemotorsports are the folks that installed that setup.
Old 06-20-2017, 12:35 PM
bobcowan's Avatar
Yeah, those are pretty helpful, too. I just wondered if you had more pictures of that particular installation.
I think I may end up putting it on the right side, and running it off of the A/C pulley. What a pain.
.boB "Iron Man"
Old 06-20-2017, 03:11 PM
am9648's Avatar
This is BDR 1591 [at VMS] which Jay is building for a customer at of his.
There a thread posted on this build and that where I copied the photo for reference.
Old 06-20-2017, 03:48 PM
bobcowan's Avatar
Found it. That's a pretty impressive build. Mine isn't nearly that impressive or high tech. Only a couple of pictures showing the alternator, and no real details. But it does give me some ideas.
I sent them an e-mail asking for more details. The parts are one off, I'm sure. But if they're willing to make them, I'm willing to buy.
BDR0572 and 1SwtRide like this.
.boB "Iron Man"
Old 06-20-2017, 05:41 PM
Gaz64's Avatar
Can the alternator be fitted in the normal manner on your passenger side just under the crank centreline next to the oil pan?
Old 06-20-2017, 08:38 PM
bobcowan's Avatar
I might end up fabbing a bracket to put it there, and then running it off of the A/C pulley. Then I'll have to fab some kind of idler pulley in place of the original alternator, or else figure out how to completely re-route to serpentine belt.
.boB "Iron Man"
Old 06-21-2017, 09:09 PM
Gaz64's Avatar
That's going to be an absolute animal when you get it running Bob.
Hope you can come up with what looks like it is "meant to there".
