Like Tree2Likes
  • 1 Post By Kobura
  • 1 Post By ItalGerBrit
Old 10-24-2017, 10:05 PM
Cobra Make, Engine: Backdraft
Default Greetings
Greetings All,
I just recently purchased my first Backdraft cobra #1124. Unfortunatly, I suffered a half shaft failure. My question is how many others have also seen the bolts backing out on the half shaft?
Old 10-25-2017, 08:34 AM
Cobra Make, Engine: Backdraft SBF-302
Previous discussion:
Help with rear differential getting loose
Old 10-25-2017, 01:49 PM
Good data! Thanks!!
Old 10-25-2017, 07:45 PM
Kobura's Avatar
Cobra Make, Engine: Backdraft RT3 #1133, Ford Racing 306
Apparently, your car was finished by Vintage MotorSports/Jay+Brian. Should you have a need, you could call them and they probably will remember the details of your build.
BTW, I know of three other BDRs here in NorCal, mine an one other are in the Bay Area and the other two are/were in the Sacramento area. if you are interested in hooking up with one of their gatherings, keep a lookout for a posting here on CC. Maybe our roads will cross one day as well.
Enjoy your car, but be smart about doing so.
BDR0572 likes this.
Old 10-26-2017, 12:55 PM
Originally Posted by Raabit View Post
Greetings All,
Someone leaving bolts loose doesn't sound like a half-shaft failure...
Old 10-26-2017, 03:36 PM
Cobra Make, Engine: HiTech, Shelby Daytona Coupe, Roush 427SR
Send a message via AIM to ItalGerBrit Send a message via MSN to ItalGerBrit Send a message via Yahoo to ItalGerBrit
Half shaft bolts backing out is not uncommon. I have had it happen many times in my race cars as well as my Hummer(H1). It is a maintenance item that should occasionally be checked. Drilling holes in the heads and then safe tying them with safety wire will prevent the backing out. Normally, you will hear the clunking early enough to stop and re-torque the bolts.
BDR0572 likes this.
Roush 427SR/T56
Old 10-29-2017, 10:15 AM
Grey 65's Avatar
Originally Posted by Ozzie Goat View Post
Not same issue, this thread is for the 6 hex bolts securing the half shaft to the output flanges of the diff.
The link you provided is for the forward 14mm hex bolt that secures the diff itself to the subframe.
Kevin......
It isn't how fast your car can go
It is how fast your car can change direction
Home of Fake Snake Racing
Old 10-29-2017, 11:59 AM
You are correct, sir.
So excited to SEE a post in the BDR forum, and I didn't find the correct search results.
Search is our friend.
Old 10-29-2017, 02:46 PM
BDR0572's Avatar
Cobra Make, Engine: BDR, Roush 402R
Default Bolts in half shafts
I check mine after a hard run for fun and have found a couple loose, I'm looking at adding safety wire holes to resolve this issue .
Old 10-31-2017, 03:52 PM
I dont think VMS did my car. Unless they just provided the rolling chasis to SRE (Spiegel Racing Engines) as he was the builder (Engine and Trans). For a while he was a Backdraft dealer in Calif. I look forward to meeting up some day in the future.
Old 10-31-2017, 04:02 PM
I suppose you could classify bolts coming loose as "not" a failure. Maybe more in line with an assembly issue. The allen bolts within the assembly, not the hex bolts on the outside are what came loose. This resulted in the half shaft breaking the rear diff cover's mounting ear (I assume that's what it is called). You really cant safety wire the allen bolts that came loose as they are all recessed. I ended up using some red loctite on reassembly and also pulled the other side apart and did the same.
Old 10-31-2017, 04:06 PM
I will say though that there is quite a bit of good information on this site that has already porven to be very helpful. As a newbie to the hotrod world it's very helpful. Thanks all!
Old 11-02-2017, 04:40 PM
Cashburn's Avatar
Backdraft Racing Dealer
You cannot have BDR1124 because that car is overseas now. Here is the build gallery: The Gallery / Roadsters / BDR1124 | \\VINTAGE MOTORSPORTS
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 11-04-2017, 10:29 PM
You are correct. It's build # 1125.
