Old 04-04-2018, 03:15 AM
lomdel's Avatar
Cobra Make, Engine: Backdraft RT3
Default BDR Speedometer Calibration
Travelling at 120kmh, my factory Backdraft speedo (kmh) indicates 120kmh while the actual GPS speed is actually just 104kmh. How do I re-calibrate the speedo to be a bit more accurate? Below is the instructions as received from the factory, but I don't understand. Where is the button (nothing on the face)? What should pulse number setting be? Any tips?
1/ Turn Ignition On
2/ Hold button down To Increase Pulse Settings at the Rear End
3/ Wait for numbers to flash - press button until desired numbers are displayed
4/ When Pressing down, it Either Goes up Or Down depending on Required Pulse Setting
5/ Once Desired Setting is Set let the Button Go and it will Register
Rate This Thread:
