Like Tree17Likes
Old 04-09-2018, 12:20 PM
Default New shocks for backdraft!
Hello!
Who can tell me what shocks are the best option as an replacement part!
Probably there are some options from europe like bilstein or other european brands as I do live in germany.
Would be glad to get help!
Thanks
Old 04-10-2018, 01:22 PM
Front shocks KYB 361005:
Application = 85-93 VW Cabrolet, 80-84 Jetta, 75-84 Rabbit, 75-89 Scirocco.
Rear shocks KYB 343144:
Application = 58-80 VW Bettle.
Old 04-10-2018, 01:35 PM
Thanks spdbrake!
Old 04-11-2018, 09:28 AM
Grey 65's Avatar
Cobra Make, Engine: BDR #888, Keith Craft 408
I use JRi double adjustable struts up front and JRi double adjustable shocks in back.
SGwick likes this.
Kevin......
It isn't how fast your car can go
It is how fast your car can change direction
Home of Fake Snake Racing
Old 04-11-2018, 12:20 PM
Default Shocks
Best shocks on the market bar none
Old 04-11-2018, 01:55 PM
Old 04-11-2018, 03:26 PM
Default Jri
Their range of adjustment, they can go from a 250 pound spring to a 1200 lb spring without revalving. This can be a curse if you don't know what you are doing you can destroy handling if adjusted incorrectly. We only move a couple of sweeps in either direction when tuning for different surface conditions.
Old 04-11-2018, 06:25 PM
Old 04-11-2018, 05:08 PM
Kobura's Avatar
Cobra Make, Engine: Backdraft RT3 #1133, Ford Racing 306
I have to believe that you know what you are doing with these JRi shocks, but I didn't know that shocks used a measurement of pounds like springs. My understanding is that shocks produce pounds of resistance to rate of compression and extension, like in inches/sec or velocity. Springs, on the other hand, produce pounds depending on their spring rate and the amount of compression. Suspension adjustments are a mystery to me, but I can understand how modern race cars probably have a computer controlling the shock settings depending upon the speed of the car and the racetrack conditions.
Old 04-12-2018, 04:45 PM
Default Shock forces
You are correct that shock forces in pounds are generally measured in inches per second. I skipped some steps just to illustrate the value of JRI's.
The higher the spring rate you run the greater the required rebound damping is. This is greatly simplified because frequencies, unsprung mass and other factors are involved. My car operates generally in the 1" to 2" per second range in an autox. If I increase my spring rate I also need to increase my rebound damping to maintain the same rebound velocity with the higher rate spring. When I was running Penske's I switched from a 1200 lb spring to an 800 pound spring and had to re-valve the shock to accommodate the new spring rate. You could do that with a JRI by just readjusting the shock.
My Porsche has electronic automatic damping control based on velocity of the suspension and many other vehicle parameters. If it were legal in our class (SS) I would have JRI dampers so we could tune the car more precisely to surface conditions. There are aftermarket electronic controls for the Porsche shocks too but they are also not legal in our class. In general as grip on a given surface comes up due to temperature, rubber on the track etc we increase rebound damping and the inverse. We also can effect dynamic balance of the car. You need really repeatable adjustments in a shock to do that and in my opinion JRI's are the best generally available short of the Multimatic DSSV shocks used on the new Ford GT and several GM products, very expensive though. Hope this helps.
Kobura likes this.
Old 04-16-2018, 06:13 PM
Kobura's Avatar
I have the KYB rear shocks that spdbrake listed and, I believe, fit a VW bug, so must be for a light vehicle application and probably is appropriate to try on a BDR. I am still searching for a better spring/shock combo. But it would be nice if there were a metric for shocks, like lbs/in/sec, so that one could determine where one was in the scale of damping to go along with the spring metric of lbs/in. Then, one could shop around for an adjustable shock that was in the range of the shock rating that seemed close to the desired value just like spring rates.
Old 04-17-2018, 05:15 AM
Kobura,
If you wanted a reasonable priced adjustable, Koni has some.
Externally 50/50 single adjustable (rebound and compression both adjusted at same time) These give roughly 100% increased dampening over Stock when at Max settings.
Front externally adjustable (via knob while installed) 50/50 dampening. PN 86411048Sport
https://www.ecstuning.com/b-koni-par...86411048sport/
For the rear they're adjustable but require full compression and turning the body to change dampening. 50/50/dampening. PN 80-2149
https://www.lmperformance.com/709063...hock-rear.html
Old 04-17-2018, 01:04 PM
I ordered the KYB shocks, that spdbrake listed!
I will give it a try for street use!
Thanks for the information !
cycleguy55 likes this.
Old 04-23-2018, 01:46 PM
Against my better judgement here goes; How do you explain the desirability of having a shock that will allow you to set bump (compression) forces to practically any force velocity curve you could possibly need and adjust rebound forces to any force velocity curve you might want.
The difficulty with explaining is that cbreeze thinks of shocks in terms of 50/50 or 70/30 or other 1960's bump rebound relationships. With that level of understanding of course you would not think having a wide range of adjustment was necessary or desirable. I suggested the Carroll Smith book because if you read it you might appreciate the value of truly good adjustable shocks. You don't have to change springs or even do a track set ups to appreciate good shocks. You can adjust them to ride as smooth as glass and absorb really nasty bumps with ease or make them aggressive if you choose to do an autox or track day. Lesser shocks do not have that flexibility, they also have higher hysteresis values which is less desirable for ideal damping. Think of it as a delay in absorbtion forces when the shock rod changes direction.
How do you adjust them: We generally use a low value for bump so that the car handles bumps well. If the car is upset by a bump say the tire leaves the ground we might reduce bump force. If the car is really bouncy and appears to be bouncing on the tires we also reduce bump force. If the car hits its own bump stops going over a bump we increase the bump forces.
Rebound is a little different, if the car jacks down after multiple bumps it probably needs less rebound if it feels like it is uncontrolled and floating we add rebound. The shocks can also alter dynamic roll stiffness during initial corner turn in or power down at corner exit. We sometimes make a change then look at lap times and cornering G loads to see if it helped or hurt. Everything you do will have effects on something else sometimes good and sometimes bad. The whole point of all this talk is that you can make a good shock do anything you want and a bad shock will have severe limitations if you are trying for ideal damping for your particular vehicle. I am sure cbreez can think of a way to belittle this answer. Since I have made many many bad decisions on shocks in the past I am just trying to help my fellow Cobra owners avoid those bad decisions. If you do not care about ride or handling by all means choose the cheapest alternative. If you do consider buying the best. Perhaps it would be appropriate at this time for cbreez to share his experience level and background so that others can make a value judgement on his comments.
Gaz64 likes this.
Old 04-23-2018, 02:32 PM
Grey 65's Avatar
And as Bill Murray so eloquently said in Stripes, "That's The Fact Jack!"
Kevin......
Old 04-23-2018, 02:44 PM
Old 04-23-2018, 03:49 PM
cycleguy55's Avatar
Originally Posted by cbreez View Post
Your beloved "Tune To Win" was written over 40 years ago...
I don't believe the laws of physics have changed markedly since it was written.
Brian
Old 04-23-2018, 05:44 PM
Old 04-23-2018, 05:54 PM
Cobra Make, Engine: BDR #509, 347 S
Good grief.
"Hey, I don't assume anything, a wrong assumption on your part."
Yet... within this VERY thread you make several assumptions. The OP never stated what his intended use was... so you made an "assumption" when you said...
"Most guys here don't try to race their cars, change springs, etc. so KISS...That's all the guy asked."
Uh... no... that's not what he asked. He asked...
"Who can tell me what shocks are the best option as an replacement part!"
You "assumed" the OP "asked for some simple advice."
In addition... you made several "assumptions" when you said the following...
"I see...so you don't know what you are talking about...just talking." and...
"It great to hear a guy talk about his own alleged knowledge and expertise!"
You do understand the meaning of the word, correct? I'm not so sure... let me help you. This example is taken from the Merriam-Webster dictionary... #3 best addresses your attempted use of the word...
3 a : an assuming that something is true
• a mistaken assumption
b : a fact or statement taken for granted
Then... when the guy you've been unabashedly hassling on this thread attempts to provide you and everyone else on this thread with a little insight... you're quick to follow with...
"Your beloved "Tune To Win" was written over 40 years ago".
Proving he was correct when he stated you would try to belittle the answer... and that's exactly what you attempted to do. Then... you make the comment that he "implied I was a bit dated in my technology thinking but he loves to throw this old book title around that he believes in...". I don't see where he implied your thinking was dated. Dated? No. But simplistic... yes.
Are you 12 years old? Why didn't you just follow that up with "Nanny, nanny, boo boo?" You're no better than a child that continually asks "What?"
You've thrown enough shade. Personally... I agree with him... it's time for YOU to share YOUR experience level and background so that others can make a value judgment based upon YOUR comments. If I don't see you offer anything up... then the question answers itself.
Maybe it hasn't occurred to you... but these threads have a life long after the last comment has been entered. They become a searchable resource for those of us looking for insight and answers. Sometimes... that's as simple as pointing someone in the right direction... and I would have been content with his reply to read the book... and I'd have gotten my hands on a copy and done just that... if I wanted to know more about the topic and make an educated decision.
One thing is certain... anytime someone in the future does a search on shocks... and this thread pops up... in addition to getting both simple... and detailed information (even if it's in the form of "what book to read")... they'll also get a firsthand account of what an insufferable a** you've been throughout it.
Maybe you should have jumped on the OP for not being more specific regarding his needs.
Either way... you're the very definition of an Internet troll. If you need help figuring out what that is... here's another link for you: https://en.wikipedia.org/wiki/Internet_troll
In the meantime... give it up. Your efforts at trying to have the last word on the topic have now literally made you and your comments a laughing stock on this thread... a joke that people will be reading about for a LONG time.
Gaz64, Grey 65 and spdbrake like this.
Rate This Thread:
