| 29 |
2Likes
06-09-2018, 09:36 PM
FS
Cobra Make, Engine: Backdraft RT3
Radiator protection
The exposed radiator gets some serious damage over time from small rocks flying into the gaping mouth of our Cobras. What do you Backdraft guys do to protect your radiators besides covering the “hole” with mesh? I want to keep the open appearance...
06-11-2018, 02:45 PM
Cobra Make, Engine: BDR, Roush 402R
06-11-2018, 03:57 PM
Most Cobras sustain little damage on their way to Cars & Coffee....
Kevin......
It isn't how fast your car can go
It is how fast your car can change direction
Home of Fake Snake Racing
06-12-2018, 05:09 AM
Ditto to BDR, this is what I use and works great.
https://www.jegs.com/i/Allstar-Perfo...30158/10002/-1
I just cut it to size and lay it in there. Stays without any fasteners. Pull it out and wash it off when it needs it.
06-12-2018, 06:34 AM
Great info. Thanks! If nothing else it keeps the bugs away from the radiator, also the oil cooler.
06-12-2018, 07:45 AM
Ne.
We use them on our sprint car, and they work well, but with our Cobra's be careful in the heat of summer, as these impeed air flow when driving slow or stopped in traffic. Keep an eye on your temp gauge at first.
Kevin
06-12-2018, 06:28 PM
Cobra Make, Engine: Superformance ford v8
Radiator protection
My Superformance came with a shield that fits in front of the radiator that looks just like a radiator.
06-13-2018, 09:07 AM
Cobra Make, Engine: Superformance , Roush 427SR dyno'd at 526 hp
I have the same thing in my Superformance and it works great
06-13-2018, 09:42 AM
Ne.
Can you guys post some photo's of just the shield ?
Where can we buy one and is it made only from Superformance ?
Kevin
06-18-2018, 04:18 PM
Cobra Make, Engine: Proud owner of Backdraft #1609
I went to my local Home Depot and purchased some window screen mesh and window screen hardware. I made my own radiator screen held in with velcro. It is easy to remove and clean and I believe I only spent around $25-$30. Comes in silver or black. But like someone said above, be sure to watch your temp gauge when city driving on a hot summer day.
06-18-2018, 04:25 PM
Make your own! Its easy! Its just regular window screen! That looks very similar to mine, but mine doesn't have the 2 supports in the middle. Mine is the same size as the radiator with velcro holding it in on the sides. You dont really need those 2 supports in the middle if the screen fits fairly tight.
06-18-2018, 04:50 PM
Ne.
I did the same. Not very nice looking, but it's cheap and it works.
Kevin
06-19-2018, 01:54 PM
IL
Here's how we did KMP259's Radiiator....
First we put Adhesive Silicone Rubber around the face of the Radiator.
Then we sealed the sides of the radiator
Then we sealed the top of the radiator
Now we fit the tight seal of the radiator into the vehicle so that no air can get past it for any reason
Now you can see how we installed the SS Wire in front of the radiator to protect it from rocks .... Also the oil cooler is exposed ...but it is much stronger then a radiator and easier to change.... if neccessary.
Packing the air in the radiator so it doesn't leak is very important ...also with the opening in the front of the car.... the air will slow down when it hits the radiator because the radiator hole is much bigger .... this is important as if you can get the air to slow down... then it cools much better....
Morris
Morris
06-19-2018, 06:05 PM
Ne.
Morris, great job.
Where did you buy the Adhesive Silicone Rubber ?
Is it a round, flat etc ?
Can you remove it at will ?
Kevin
06-19-2018, 07:15 PM
IL
McMaster Carr they have everything......
Also got the SS mesh wire there as well....
The Silicone is flat a then we got some 1/4” Silicone hose and split it to go on all of the sheet metal edges...
Morris
06-19-2018, 07:35 PM
Ne.
Thanks buddy.
Kevin
06-21-2018, 05:16 AM
AL
I bought a piece of stainless at a mechanical shop and tig it to 1/4" chromoly tubing.
worked great for 42,000 miles
06-22-2018, 05:48 AM
Fl
Cobra Make, Engine: BDR #178 United Speed World Special
I use the top of an aquarium. Stainless steel screen with a plastic screen. fits tight and you can pull it out and clean the bugs and debris easily.
Doing and driving what other people dream about!
06-22-2018, 06:07 AM
I also use the Nomex screen from Speedway. It comes in tan so I sprayed it with aluminium colored paint. Easily cut to size with HD scissors, installed with industrial Velcro. I did use heavy needle and thread to attach the Velcro to the screen since the hook and loop was stronger than the adhesive on the screen. Takes a minute to remove for cleaning. I did notice a 5° increase in running temperature, in our AZ heat. Well worth it for the peace of mind.
Karlos
06-23-2018, 08:37 PM
Cobra Make, Engine: Backdraft #1333, Smeding 427
I’ve put a lot of miles on my Backdraft, on and off the track. The radiator opening is a crap-catcher, for sure, but I have yet to experience anything more than cosmetic damage. If it gets to the point that I can’t look at it anymore or suffer serious damage, I can replace that radiator over an afternoon and for a trivial expense. A lot less complicated and expensive than the radiators on my Porsche that are located behind gaping openings... I have screens to protect the radiators on that car.
FWIW, the best protective strategy for the Cobra radiator is to lead, not follow, any other cars
