Like Tree1Likes
  • 1 Post By eschaider
Old 04-25-2019, 06:58 PM
FredG's Avatar
Default Steering Quickener
Hi everyone.
Has anyone had any experience and success with installing a steering quickener on a manual steering Backdraft to improve the steering response.
Fred
Old 04-26-2019, 08:52 AM
bobcowan's Avatar
I'v never used one. Wouldn't that increase steering effort?
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 04-26-2019, 09:20 AM
Grey 65's Avatar
Originally Posted by FredG View Post
Hi everyone.
Fred
Just put a BMW Z3 rack in the car using a KRC pump...
Kevin......
It isn't how fast your car can go
It is how fast your car can change direction
Home of Fake Snake Racing
Old 04-26-2019, 07:57 PM
FredG's Avatar
Car has electric steering in it that works very well but I am not happy with the response I get from the current rack which I understand comes from a Toyota Pickup. Seriously, Toyota rack installed by the factory in a Backdraft cobra?
Old 04-26-2019, 08:36 PM
Karl Bebout's Avatar
FredG, you're shocked that Backdraft used a Toyota rack? BMW stuff is OK, but not Toyota? Even the revered CS used about anything that would do the job, or that he had laying around in the corner...
Karlos
Old 04-27-2019, 11:55 AM
Cobra Make, Engine: Backdraft SBF-302
you should see what your camber and caster are before going after hardware
Old 04-27-2019, 12:40 PM
Typically, trucks have much slower turning racks to accomodate loads, larger tires, etc... I would call Backdraft to see if they know of a rack with the same specs but faster turning specs. I would suspect the BMW they used to use would come with a faster rack but you would have to verify with Backdraft or somebody who knows how to measure your existing geometry or rack to match it up....
Old 08-06-2019, 07:21 AM
hauss's Avatar
If you want to turn quick just stab to the go pettal you will be amazed how quick you will turn! Just work on your skills a little driving your car rather than trying to reengingineer it.
Old 08-06-2019, 12:39 PM
eschaider's Avatar
Fred,
As you quicken manual steering you increase the car's ability to manhandle you through turns on a road course or elsewhere. If you quicken the steering by using a power assisted rack you increase the control you have and decrease the car's ability to manhandle you through the turns.
Take a look at this video of a Cobra on the track and watch how the driver fights the wheel to maintain control of the car. Click here => Cobra Vid...Pay attention around the 45 second mark. This is the first of several fairly impressive battles between man and machine.
On a road course, it is a continuous battle between man and machine. Anything you can do to get a leg up, so to speak, in the battle is worth doing. Quickening steering w/o something like a power assist to help you maintain control might be less attractive than you suspect.
Ed
hauss likes this.
Old 08-06-2019, 03:45 PM
cycleguy55's Avatar
Including Volkswagen steering columns!
Brian
Old 08-12-2019, 09:05 AM
hauss's Avatar
Originally Posted by eschaider View Post
Fred,
Ed
Way beyond my skills! that was crazy! I was starting to sweat just watching.You are correct steering quickeners are a good thing.
Old 08-13-2019, 04:02 PM
bobcowan's Avatar
How much of a "bolt in" process is this rack? Any particular year/model better than others?
I'm thinking of doing exactly this.
.boB "Iron Man"
Old 08-14-2019, 04:09 AM
Grey 65's Avatar
Pretty easy actually... You can get the entire kit 3.2 turns and an aftermarket rack from Backdraft... Or you can do what I did and call Backdraft and get their install kit minus their 3.2 turn aftermarket rack and then source a real OEM BMW Z3 rack which is what I did. You can get a rebuilt OEM Z3 rack from the The Rack Doctor He has 3 racks.. You can buy either the 96-97 or the 98-02 NON 3.2L rack. The 3.2L rack is 3.2 turns and the other two are 2.7 turns.
Kevin......
