Like Tree1Likes
  • 1 Post By hauss
Old 07-04-2019, 08:18 AM
hauss's Avatar
Smile clutch master
Well I finally fixed my clutch problem,after replacing 3 slave cylinders. I never saw the fluid leaking out of the master cylinder, on the clutch because it was under the carpet . What a job, not for old men, I"m just saying laying across the motor from the opposite side of the car, reaching inside the fender, was not very easy. I will say thank you to mr. Cashburn, for the removing the side louver, to get at the clutch master cylinder. By the way that was a job in it"s self. There is a alien bolt in the fire wall, in front of the headers, that even a child hands would not fit . Anyway got it all done it it works great.
Old 07-05-2019, 04:30 PM
Cobra Make, Engine: Factory Five, 351 Winsor
Good for u done mine as well, like u said not easy
Old 07-05-2019, 05:03 PM
Gaz64's Avatar
Were any of the 3 slave cylinders leaking?
With any clutch issue, if a slave cylinder is not leaking, it is not the cause of the fluid loss, then you move on to checking the rear of the master cylinder.
Old 07-06-2019, 08:44 AM
hauss's Avatar
AS Patrick would say it was part of my learning curve .Some curves are longer than others.
Gaz64 likes this.
Old 07-06-2019, 09:16 AM
The object is to have the curve continue out, but with a gradually diminishing slope. And try to avoid having the curve ending abruptly.
Old 07-06-2019, 08:36 PM
hauss's Avatar
I"m trying patrickt, but that how it goes sometimes, on the unfamiliar road.
