Old 02-02-2020, 10:05 PM
Cobra Make, Engine: Backdraft BDR4 GT
Default Cold air intake solution for Coyote engine
Hi,
what's your cold air intake solution at your coyote engine?
Did you fabricate the pipe?
Where did you mount the sensor etc?
Thanks in advance
Old 03-19-2022, 04:37 PM
Cobra Make, Engine: BDR #1368, Coyote Gen1
Hi Coach36,
What did you end up doing for your Coyote? Mine was set up with the tube extending directly to the radiator. I’ve seen others setup like this too. Seems like that’s where the hottest air would be? So looking at a new tube to run it to the side. Thoughts?
