Old 05-28-2020, 12:14 PM
Cobra Make, Engine: Backdraft 1048
Default Starter issue
Every few starts when I press the starter button I hear the starter turn but not the engine. Third attempt it works fine. Sounds like the Bendix spring? It's a Roush 427SRXE. If starter needs replacement what is recommended?
Thanks
Gary
Backdraft 1048
Old 05-28-2020, 03:59 PM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Default check
Hi,
Check the engine ground cable is secure. I always add a 2nd ground cable to the engine block near the bellhousing.
Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
Old 05-28-2020, 04:21 PM
bobcowan's Avatar
If you end up replacing it, I would recommend a standard replacement from Autozone (or wherever) for a mid 90's Mustang with a 302/5.0. It's a direct bolt in, high torque motor, and a lifetime warranty.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
