Like Tree2Likes
  • 2 Post By Shizznizz
Old 08-19-2020, 11:16 PM
Cobra Make, Engine: Backdraft BDR4 GT
Default Tank setup
Hey,
does someone run a fuel injected engine and gets the fuel delivered in the BD plastic tank by a internal fuel pump?
Old 08-19-2020, 11:38 PM
Not on my Backdraft, i'm using an external swirlpot and Bosch EFI pump.
However, on my GT40 I did build it with an in-tank EFI pump, and its working fantastic. I should actually go back to my cobra and convert it.
I'm using the Aeromotive Phantom package, an EFI pump with a baffle foam insert, such that you don't need a swirl pot. I'm positive this will also fit in the plastic Backdraft tank.
ERA 626 and coach36 like this.
Old 08-24-2020, 07:47 AM
lomdel's Avatar
Cobra Make, Engine: Backdraft RT3
I have a fuel injected engine and run the stock plastic fuel tank and stock in-tank fuel pump. No problems at all...
Old 08-24-2020, 04:53 PM
Gaz64's Avatar
There's nothing wrong with a good plastic tank fuel system.
They don't corrode and don't get as hot as any metal, and unlikely to crack at welded seams.
If you must have the look of an aluminium tank, make up a fake undercover.
