Like Tree1Likes
  • 1 Post By SBSerpent
Old 10-30-2021, 01:21 PM
SBSerpent's Avatar
Cobra Make, Engine: BDR build #983, FRM 392
Default Instrumentation lighting
How does the lighting on the VDO gages work? Is there a small light bulb that fits into the back of the gage?
My fuel gage needle lights up nicely but the numbers on backface don't appear as bright as on the other gages. Wondering whether changing out the bulb will help remedy my issue.
Old 10-30-2021, 02:29 PM
They use 158 4watt wedge base bulbs.
Your bulb socket may not be fully seated in the gauge causing the dimness, or someone may have installed a off brand bulb.
Snaps out of the back of the the gauges.
https://www.summitracing.com/parts/vdo-600840?rrec=true
Bulbs (4 to a pack if you'd like them all to look the same) https://www.summitracing.com/parts/vdo-600815?rrec=true
You can get these at NAPA , Autozone etc...
Red bulb boots (They go on mucho easier with squirt of isopropyl alcohol)
https://www.summitracing.com/parts/v...xoChC0QAvD_BwE
Easy access if you pull the speedo out. No need to disconnect it.
Old 10-31-2021, 06:44 AM
FredG's Avatar
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Bulbs
If you are looking for something brighter you could probably find some LED's to fit. I went a different route and swapped out the gauges for upgraded Autometers. Carbon fiber ones, with LED lighting, to match my dash and replaced all the colored idiot lights with small LED's. Much brighter.
Old 11-03-2021, 05:30 PM
SBSerpent's Avatar
Just to be clear, there is one bulb in the small gages and two bulbs in the larger gages (speedo and tach)?
Ordered direct replacement T10 red LEDs so hopefully that should dramatically improve the illumination.
Old 11-07-2021, 03:56 PM
SBSerpent's Avatar
Wow! What a pronounced improvement with the LED bulbs!!!
Ozzie Goat likes this.
Old 11-15-2021, 12:21 PM
FredG's Avatar
Default LED's
Yep......I felt like I was looking at the dash lights from a car in the 60's with those small incandescents. The LED's really get it done.
Rate This Thread:
