November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree8Likes
  #21 (permalink)
Old 09-21-2022, 04:22 AM
Great looking and sounding cobra!We saw a cobra
A that a bit like it this past week in Ocean city,NJ man was it cool and loud!You've got a great car!John and Ellie
BDR0572 likes this.
  #22 (permalink)
Old 10-09-2022, 07:10 AM
BDR0572's Avatar
Cobra Make, Engine: BDR, Roush 402R
Originally Posted by Say When! View Post
Hi All , I have a 2022 Backdraft with a 427 Chevy. My mate bought exact same and we both have the most annoying rattling from the side pipes on deceleration and just above idle , not only is it anoying but embarrasing .
Anyone figure out a solution or alternative pipe that has removed this sound?
yep, it is the aft support brackets on mine, i bought a small dia washer drilled the hole to allow bolt and used as a shim tighten up fit also had an issue with a bracket hitting mount .. had to grind it down about an 1/16 { bracket is wider than spacer,} it will stop brackets on pipe from pinching and tightening up, leaving aft support bracket to rattle at stops and so far no more rattle
  #23 (permalink)
Old 11-30-2022, 05:49 PM
Cobra Make, Engine: BDR 4.6 LTR 3V FRPP HOTROD CRATE ENGINE
Hi "say when " , have you found the rattle yet, it could be the catalytic converters, my friends bdr had a broken cat and that was a embarrassing rattle.
  #24 (permalink)
Old 11-30-2022, 11:44 PM
Cobra Make, Engine: BackDraft
Originally Posted by tonywyso View Post
I have to ask, has anybody cut the muffler part off the side pipe and just used a straight thru pipe ?
Yes! It’s one of the best modifications I have done to the car. Cut them, pulled the guts out and had a shop tig weld them back together. It’s insanely loud, but I absolutely love it!
