Like Tree7Likes
  • 2 Post By Mike_Gr
  • 1 Post By Mike_Gr
  • 1 Post By Mike_Gr
  • 2 Post By Mike_Gr
  • 1 Post By Mike_Gr
Old 06-05-2022, 12:52 PM
Default Finally got my hard top installed, thanks Vintage Motorsports!
Love the new top, cant wait to get the front apron installed to see how it help with stability of the car
jolsen42 and SGwick like this.
Old 06-05-2022, 01:05 PM
mattbrowne's Avatar
Looks great!!!
A good friend will bail you out of jail. A great friend will be sitting next to you saying damn that was fun.
Old 06-05-2022, 01:26 PM
Looks incredible. Curious - how easy is the “on / off” of it and total weight? I am planning to get one with my car when the build is done.
Old 06-05-2022, 04:17 PM
What kind of AC are you going to put in it? It's going to get warm in there.
Old 06-05-2022, 05:08 PM
Ive heard from several people with hard tops that it is actually cooler without the sun beating down on you with the top on.
Vel87x likes this.
Old 06-05-2022, 05:13 PM
Havent actually had to take it off yet, only had it for two days before I brought it back to have the rest of the work finished. Just grabbed it for my track day. It is only 4 attachment points on the body, the two hinges on the windshield frame and the tension rod in the center of the windshield. I have a hoist set up in my garage from when I had a Jeep Wrangler for about two months before trading it in for a pick up so I could tow the cobra. Hopefully that will work.
Corner weight with nobody in the car shows it to weigh in at 2799 with the top. I have been told it is easy to lift off with one person on each side.
Bitten21 likes this.
Old 06-05-2022, 05:37 PM
When you get in the car ...your body weight will only be on the LF, LR, & RR....
Morris
Old 06-05-2022, 05:58 PM
The car was corner weighted with driver in it after the one I showed above. Only showed that as they asked total weight with top. Slightly higher weight on left side of car. Cross weights are really close. I am thinking of getting a set of scales so I can play around with this a bit after I dial in the suspension. That in itself is completely adjustable now so could take a bit of fine tuning.
Old 06-05-2022, 07:37 PM
I have heard the same. Being in the Chicago weather I am going to add the top and a heater to get a few more months out of it before it goes up in the winter.
Old 06-06-2022, 05:21 AM
SGwick's Avatar
Cobra Make, Engine: VMS #2273
Looking great Mike! I'm bias though :-)
Old 06-06-2022, 10:57 AM
Racing in Tamworth , NH ?
Dan
427 CSX 3000/4000 and Shelbys.
All gone ! Was a Hell of a run
Now ... The dogs car
Mercedes E63S station wagon. 603hp
That was one factor for me too, extending the driving season in Ma. I dont have a heater but did add heated seats.
BDR0572 and Bitten21 like this.
Old 06-06-2022, 10:59 AM
Thompson Speedway in CT
Old 06-06-2022, 11:00 AM
Our cars look almost identical, yours having the GT body and mine having the ghosted wide center stripe.
SGwick likes this.
Old 06-06-2022, 06:25 PM
Your tire temps when you come in off track are very important to balance the chassis.....also the tire pressure is equally as important....
So the question becomes do change a tire pressure....or a corner height...or a sway bar setting ...or a shock setting...multiple choice.....
Morris
Old 06-07-2022, 05:50 PM
Yup agree. I keep a log book of shock settings, tire pressures and tire temps. Just swapped to a set of adjustable sway bars and haven't starting messing with those yet. Still playing mostly with tire pressures (and tires them selves depending on weather with my hoosiers and Nittos) and shock settings at the moment.
