Like Tree10Likes
Old 04-27-2023, 02:41 PM
bobcowan's Avatar
Neutral
Default Fuel Level Sender
It works!
As we all know, the fuel level sender is not that great. It's OK, and it works; in it's own way. But we all know it could be better.
A couple of weeks ago, someone posted on the FB group about this new Holley IR sender. Looked like the perfect thing, so I ordered one from Summit Racing. They said it was B/O until the end of May, But I received it in about a week.
Installation is pretty straight forward. It only took me about an hour. The stock sending unit has two wires - ground and gauge. The new one also needs power. I pulled that from the electric fuel pump next door.
I cut the pigtail off the original sender, and used that for the new one. Made it a simple plug in.
The bolt pattern is an exact match, and uses the same thread pitch for the new longer screws.
I still need to mess with the calibration a bit, but it works prefectly. Nice a smooth, appears to be pretty accurate. We'll see how it goes on the next road trip. 🙂
At some point, I want to change the gauges to something better. All I will need to do is recalibrate the sender.
I'm pretty happy about this. 🙂
eschaider, BDR0572, Bob K and 1 others like this.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 04-27-2023, 04:03 PM
twobjshelbys's Avatar
No fair. I always thought the mental calibration process for the fuel gauge was part of the Cobra fraternity hazing.
BDR0572 likes this.
Tony
CSX4005LA
Old 04-28-2023, 05:56 AM
Just ordered one. Thanks for sharing!
Old 04-28-2023, 08:03 AM
eschaider's Avatar
Thanks for being the test case, Bob.
I had been looking at that sender for a couple of weeks now, mired in indecision. When you did your gauge calibration, were you calibrating for Nisonger/Smith gauges or some other gauge?
Thx,
Old 04-30-2023, 07:14 PM
Cobra Make, Engine: BDR 4.6 LTR 3V FRPP HOTROD CRATE ENGINE
Will these sender units be a direct/ easy fit to the plastic fuel tanks?
Old 05-07-2023, 04:50 PM
bobcowan's Avatar
IDK. I've never seen a plastic tank. I don't know what the sender looks like for those. If it has 5 screws holding it in place, it is probably the same bolt pattern.
.boB "Iron Man"
Old 05-07-2023, 07:10 PM
That sounds promising, the unit in the plastic tanks have a 5 bolt pattern as well
Old 05-08-2023, 11:32 AM
bobcowan's Avatar
Looks like it should work. I would buy it, and then if it doesn't fit you can return it.
.boB "Iron Man"
Old 05-09-2023, 07:02 AM
I will be getting one of those for sure, they're only available in the US so I will wait till I have decided on if I get a ali tank and new fuel pump, thanks again
Old 05-19-2023, 04:39 AM
Cobra Make, Engine: Superformance-Port fuel injected 427 stroker.
Mine will be here this weekend.
2003 SPF 351W/427 stroker with port fuel injection. Royal Blue and Polished 17's.
Old 07-07-2023, 08:31 AM
Cobra Make, Engine: Backdraft - Coyote
Bob, I see you have an access panel in the trunk floor to get to the pump. Mine doesn't. Did that come stock with the car, or did you retrofit it? Maybe the year of the vehicle has something to do with it? Mine is either a 2011 or 2012. Thanks.
Old 07-09-2023, 03:26 PM
bobcowan's Avatar
The access panel was installed at the factory. My car is a 2016.
.boB "Iron Man"
Old 03-14-2025, 08:14 PM
Toddh03's Avatar
Cobra Make, Engine: Backdraft BDR RT4
Resurrecting an old thread.
I'm hoping Bob will see this post and reply. I have a 2021 bdr rt4 with the bdr autometer type gauges. Once my fuel gauge gets close to around a half tank then for no reason it drops to empty, between full and half it seems to be fairly accurate.
So Bob how did this Holley lidar fuel tank sensor work out for you? Was it easy to calibrate etc etc?
Thanks in advance as I'm looking at replacing my fuel tank sender!
Todd
Backdraft BDR RT4 427 Number 2172
Old 03-16-2025, 10:35 AM
bobcowan's Avatar
Yes, it is still working well. Initial programming was pretty easy, just follow the instructions.
After the initial install, I fiddled with the programming a bit to get it just where I wanted it.
Be sure to use thread sealer on the mounting bolts, or you will get a leak.
CompFi likes this.
.boB "Iron Man"
Old 03-16-2025, 12:55 PM
Toddh03's Avatar
Great and thank you for the reply Bob, I just ordered me one.
These forums are awesome.
Old 11-18-2025, 08:46 AM
@bobcowan thanks for the write-up. What gauges are you using with this Holley fuel sender? Autometer?
@Toddh03, did you get yours installed? How is it working and what gauges are you using?
Old 11-22-2025, 08:15 PM
bobcowan's Avatar
Still the standard BDR gauges. I keep saying I'm going to replace them, but still haven't done it.
.boB "Iron Man"
Old 11-23-2025, 01:22 PM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Default Shiny inner tank surface?
Folks:
I just installed a new BDR aluminum fuel tank w/internal pump to work with my Pro Flo 4 EFI system. I'm reading at Summit Racing that some of the people trying to use this sending unit are getting wildly inaccurate readings due to the shiny inner surfaces of their aluminum fuel tanks. Anybody out there put this unit on a shiny aluminum tank with success?
Thanks
Bill
"If your work speaks for itself, don't interrupt"
Old 11-27-2025, 01:00 PM
bobcowan's Avatar
My tank is aluminum. I had to fiddle with the sender to get it just right. Now it seems to work fine, and is fairly accurate.
CompFi likes this.
.boB "Iron Man"
Old 11-28-2025, 07:30 AM
Sledge's Avatar
Thank you Bob
Bill
