Old 09-19-2023, 07:23 AM
Cobra Make, Engine: Backdraft 427
Default Brake noise
I have a little over 800 miles on my Backdraft Cobra and have started hearing a chirping noise when I first push the brakes. It's faint but I think it's coming from the rear. Usually when I let off of the brakes and re-apply I don't hear it. Any one else experience this? Thanks for any help
Old 09-19-2023, 10:03 AM
eschaider's Avatar
I have a friend who has a Backdraft — same problem!
Turns out a sparrow built a nest in the chassis under the glass and gets pissed off every time Bob starts the car to drive it. Once the car moves, the sparrow throws a fit and starts to chirp. As soon as the car is shut down, silence returns.
Old 09-19-2023, 10:10 AM
twobjshelbys's Avatar
Or it's the "crickets" built in to the pads of most civilian vehicles that chirp when the pads are worn down. Are you sure the pads are OK?
Tony
CSX4005LA
Old 09-19-2023, 12:40 PM
Only 800 miles on them... got a mechanic friend thats gonna take a look but any suggestions are appreciated!
Old 10-04-2023, 05:39 AM
Hi did they fix your brakes? Do you have Wilwood brakes ??
Old 10-04-2023, 06:33 AM
Probably some vibration of caliper parts that causes the noise. Pull the wheel(s) and at the very least lube up the caliper pins and anything else that looks like it may be metal to metal contact.
Shouldnt need to fully remove the caliper or need to rebleed brakes.
Old 10-04-2023, 07:46 AM
If you’re in a damp climate, you might have a little rust on the rotor that disappears after the first brake application. Then reappears when the car sits.
Jim
Old 10-06-2023, 09:19 AM
Cobra Make, Engine: Backdraft BDR4 GT
On mine it was the clamps which hold the pads in place. There is a way too small gap between the clamp and the rotors.
