Like Tree1Likes
  • 1 Post By patrickt
Old 10-06-2023, 09:30 AM
Cobra Make, Engine: Backdraft BDR4 GT
Default Windshield
Hey, I'd like to give my windshield a little bit more rake. A more laid back look. Anyone done that? What needs to be done?
Old 10-06-2023, 09:47 AM
With the caveat that I have never touched a BDR's windshield... ever... I would point you to the windshield posts and the bolts and holes in the picture below (which is not a BDR, but I'm betting it's close). See if you can loosen those bolts and then adjust the windshield rake to your liking and then retighten. This is how you get an ERA's windshield to mate just right with side curtains.
HighPlainsDrifter likes this.
Old 10-07-2023, 01:17 AM
Dominik's Avatar
You could even drill all holes a bit bigger to allow more play. Bear in mind that your soft top won't fit anymore after you did this.
A former racing driver (Shelby team) claimed 500 to 800 rpm more down the long straights with a 289. But that rake was drastic. Angle had probably discussed here a few times.
If I don't respond anymore, that's because I can't log in
Old 10-11-2023, 06:37 AM
FredG's Avatar
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Windshield
I took my windshield out when I replaced the dash. The windshield is straight across and comes out easily. You could, potentially, modify the ear or make a small bracket to do what you are proposing. There is not a lot of room under there. Just be warned that the windshield will easily break if put under torque or tension when re-installed. You could, potentially, run into a sealing problem on the bottom. Good Luck.
Fred
