Old 02-22-2004, 06:24 PM
Cobra Make, Engine: Backdraft #101, 342 stroker
Default More wiring questions
Boudy or Regg,
I am installing my drivetrain myself. I have only seen the very basic wiring instructions. I have Autometer gauges. Is it possible to get detailed wiring diagrams for my car. I am NOT using a MSD box. I have a Mallory Unilite distributor, a mechanical fuel pump, and a Edelbrock Carb.
What wiring harness is used in the Backdraft? Do they have any detailed diagrams?
As you can see, the basic wiring diagram I have seen does not apply to my set-up.
I know I won't be using the wires for the electric fuel pump, but there are others I can't figure out. There is a fuse for reverse gear lighting, is that the other wire harness in the rear?
Any help would be greatly appreciated.
tfarhood
Old 02-23-2004, 07:19 PM
Boudy's Avatar
Cobra Make, Engine: BDR #42, 425HP 347 - NASA TX, CMC #55 Mustang Road Racer - Legends 37' Chevy Coupe #43 Oval Racer - Honda CRF450R(I'm afraid to race it), 95' Black Lighting Daily Scooter
Sorry, I have only installed MSD boxes in everything I've ever built, raced, or sold.
The harness is built in house. I'll have someone get in touch with you.
Boudy
Old 02-23-2004, 09:02 PM
Cobra Make, Engine: Midstates, Genesis 427 S/O
Try emailing Dr. K's, their email address is ; drkswire@hotmail.com,
they design automotive wiring. Maybe they can help.
Slithering
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
Old 02-23-2004, 09:13 PM
Cobra Make, Engine: BDR Roadster ,427 R
Hi there,
The wiring harness in the car is custom made for us. They do have a few extra circuits installed for different applications. The newer spec cars have an extra circuit for backing-up lights which is necessary in some states.
If you are having a problem getting it hooked up for your particular application, give me a ring or drop me an e-mail explaning exactly what you are using and I should be able to guide you through it. Although the car is set up to use a MSD ignition it can be wied for anything. There are 4 wires in the car for this . You woll find a green,purple,orange and black on the eng harness which correspond to the MSD colors. You will also find the corresponding wires under the dash by the fuse box on a different loom. You could probably use the orange and black for the coil and possibly the green to supply the feed to the distributor. I am not sure what your application requires but it should be easy to figure it out.
This will probably be better to explain on the phone or on a detailed e-mail with all the facts.
Regards Reg
561-752 3693
www.Backdraftracing.com
Old 02-24-2004, 03:14 PM
Thanks Regg, you will get a call and an e-mail from me in about a week when this part all comes together.
tfarhood
